Ich bräuchte mal Hilfe mit der Änderung der Konfiguration, damit wieder Updates funktionieren.
Ich habe schon was geändert, bekomme aber folgende Fehlermeldung:
> Updating /config/esphome/esp-temp-1.yaml
> INFO ESPHome 2024.7.3
> INFO Reading configuration /config/esphome/esp-temp-1.yaml...
> Failed config
> dallas: [source /config/esphome/esp-temp-1.yaml:40]
> The "dallas" component has been replaced by the "one_wire" component.
> https://esphome.io/components/one_wire.
> - pin:
> number: GPIO2
> mode:
> input: True
> pullup: True
> update_interval: 60s
> ========= [ERROR] /config/esphome/esp-temp-1.yaml =========
> ======================== [SUMMARY] ========================
> - /config/esphome/esp-temp-1.yaml: FAILED
Hier mein Script:
> esphome:
> friendly_name: ESP-Temp_1
> esp8266:
> board: esp01_1m
> # Enable logging
> logger:
> # Enable Home Assistant API
> api:
> encryption:
> key: "zXPnTC3x92SE+1g9nOrr3OAddiM+AbkO2gqakQbN/+w="
> ota:
> password: "5d9ffa6697a64c094960e0ac7ef31ab2"
> platform: esphome
> wifi:
> ssid: !secret wifi_ssid
> password: !secret wifi_password
> # Enable fallback hotspot (captive portal) in case wifi connection fails
> ap:
> ssid: "Esp-Temp-1 Fallback Hotspot"
> password: "ZrbO7TMnYJCn"
> captive_portal:
> one_wire:
> - id: bus_one
> platform: gpio
> pin:
> number: GPIO2
> mode:
> input: true
> pullup: true
> dallas:
> pin:
> number: GPIO2
> mode:
> input: true
> pullup: true
> sensor:
> - platform: dallas
> address: 0x1bac73730a646128
> unit_of_measurement: "°C"
> icon: "mdi:thermometer-plus"
> device_class: "temperature"
> state_class: "measurement"
> accuracy_decimals: 1
> - platform: dallas
> address: 0x92f27f730a646128
> name: "Heizung Rücklauf"
