### What happened?
Hi!
I recently purchased several Avatto thermostatic valv…es. Everything works fine except for one stupid thing:
When I change from heating to automatic, the temperature at my valve always increases to 153.6 degrees.
Changing the hours or temperatures doesn't change anything. I use SONOFF Zigbee 3.0 USB Dongle Plus ZBDongle-P.
The problem was reproduced on my 7 ME168 valves. Always the same.
Below I have pasted an example schedule from my z2m configuration:
`00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0`
And some logs from my z2m (after setting a schedule)
Look at the last line.
Regards!
### What did you expect to happen?
I expected that my schedule will set proper temperature :)
### How to reproduce it (minimal and precise)
Just set values on the valve (e.q. via "exposes" tab in z2m, or via MQTT `zigbee2mqtt/FRIENDLY_NAME/set`
### Zigbee2MQTT version
1.33.2 commit: 311ea07
### Adapter firmware version
20210708
### Adapter
### Debug log
`debug 2023-11-20 14:55:37Publishing 'set' 'schedule_monday' to 'termostat-gabinet'
debug 2023-11-20 14:55:39Received MQTT message on 'zigbee2mqtt/termostat-gabinet/set' with data '{"system_mode":"auto"}'
debug 2023-11-20 14:55:39Publishing 'set' 'system_mode' to 'termostat-gabinet'
info 2023-11-20 14:55:40MQTT publish: topic 'zigbee2mqtt/termostat-gabinet', payload '{"battery_low":false,"child_lock":"UNLOCK","current_heating_setpoint":21,"error":null,"frost_protection":"OFF","linkquality":75,"local_temperature":21,"local_temperature_calibration":0,"running_state":"heat","scale_protection":"OFF","schedule_friday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","schedule_monday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_saturday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_sunday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_thursday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_tuesday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_wednesday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","system_mode":"heat"}'
debug 2023-11-20 14:55:40Received Zigbee message from 'termostat-gabinet', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1,0,0,0,160,7,0,0,180,15,0,0,190,18,0,0,180],"type":"Buffer"},"datatype":0,"dp":28}],"seq":19712}' from endpoint 1 with groupID 0
info 2023-11-20 14:55:40MQTT publish: topic 'zigbee2mqtt/termostat-gabinet', payload '{"battery_low":false,"child_lock":"UNLOCK","current_heating_setpoint":21,"error":null,"frost_protection":"OFF","linkquality":69,"local_temperature":21,"local_temperature_calibration":0,"running_state":"heat","scale_protection":"OFF","schedule_friday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","schedule_monday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_saturday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_sunday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_thursday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_tuesday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_wednesday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","system_mode":"heat"}'
info 2023-11-20 14:55:40MQTT publish: topic 'zigbee2mqtt/termostat-gabinet', payload '{"battery_low":false,"child_lock":"UNLOCK","current_heating_setpoint":21,"error":null,"frost_protection":"OFF","linkquality":69,"local_temperature":21,"local_temperature_calibration":0,"running_state":"heat","scale_protection":"OFF","schedule_friday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","schedule_monday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_saturday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_sunday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_thursday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_tuesday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_wednesday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","system_mode":"auto"}'
debug 2023-11-20 14:55:40Received Zigbee message from 'termostat-gabinet', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0],"type":"Buffer"},"datatype":4,"dp":2}],"seq":19968}' from endpoint 1 with groupID 0
debug 2023-11-20 14:55:59Received Zigbee message from 'termostat-gabinet', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,6,0],"type":"Buffer"},"datatype":2,"dp":4}],"seq":20224}' from endpoint 1 with groupID 0
info 2023-11-20 14:55:59MQTT publish: topic 'zigbee2mqtt/termostat-gabinet', payload '{"battery_low":false,"child_lock":"UNLOCK","current_heating_setpoint":153.6,"error":null,"frost_protection":"OFF","linkquality":66,"local_temperature":21,"local_temperature_calibration":0,"running_state":"heat","scale_protection":"OFF","schedule_friday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","schedule_monday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_saturday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_sunday":"00:00/16.0 08:00/18.0 10:00/20.0 18:00/18.0","schedule_thursday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_tuesday":"00:00/16.0 07:00/18.0 15:00/19.0 18:00/18.0","schedule_wednesday":"00:00/16.0 07:00/19.0 09:00/20.0 18:00/18.0","system_mode":"auto"}'`
