Habe heute das Update von Zigbee2MQTT gemacht und seitdem startet es nicht mehr. Komischerweise hilft auch ein Restore nicht. Weder ein Zigbee2MQTT noch ein komplettes Backup führt zu einer Lösung. Zigbee2MQTT bleibt tot.
LOG ist:
[09:51:27] INFO: Preparing to start...
[09:51:28] INFO: Socat not enabled
[09:51:29] INFO: Starting Zigbee2MQTT...
[2024-07-02 09:51:42] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-07-02 09:51:42] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
at SerialDriver.resetForReconnect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:347:19)
at SerialDriver.emit (node:events:517:28)
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:348:22
at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
at SerialDriver.openSerialPort (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:108:13)
at SerialDriver.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:63:13)
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:353:17)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:164:13)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
[2024-07-02 09:51:57] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-07-02 09:51:57] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
[2024-07-02 09:52:17] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-07-02 09:52:17] error: zh:ezsp:ezsp: Connection attempt 3 error: Error: Failure to connect
[2024-07-02 09:52:42] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-07-02 09:52:42] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: Failure to connect
[2024-07-02 09:52:42] error: z2m: Error while starting zigbee-herdsman
[2024-07-02 09:52:42] error: z2m: Failed to start zigbee
[2024-07-02 09:52:42] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-02 09:52:42] error: z2m: Exiting...
[2024-07-02 09:52:42] error: z2m: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:370:19)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
by HarryP: Post formatiert
