Getestet habe ich es mit einer Inject-Node vor der Verzögerung, da ich keinen Eingang bei der “events: state” Node hinbekommen habe um dort zu starten.
[{"id":"44884235f083196f","type":"tab","label":"Testen","disabled":false,"info":"","env":[]},{"id":"ee625b19310b3965","type":"server-state-changed","z":"44884235f083196f","name":"Wenn Sabse geht","server":"be07aea0.e26e6","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"person.sabse","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"not_home","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":180,"wires":[["1db00fba8cbf19c2"],[]]},{"id":"1db00fba8cbf19c2","type":"delay","z":"44884235f083196f","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":240,"y":280,"wires":[["c7906841b3025275"]]},{"id":"c7906841b3025275","type":"api-current-state","z":"44884235f083196f","name":"","server":"be07aea0.e26e6","version":3,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"person.sabse","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"2","forType":"num","forUnits":"seconds","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":520,"y":280,"wires":[["78761d3a6e7869a4"],[]]},{"id":"78761d3a6e7869a4","type":"function","z":"44884235f083196f","name":"function 9","func":"const ort = msg.data.old_state.state;\nmsg.payload = { \"data\": { \"message\": \"Sabrina hat \" + ort + \" verlassen(Node-RED Info)\" , \"title\": \"Abwesenheitsbenachrichtigung!\", \"data\": { \"push\": { \"thread-id\": \"Sabsestatus\" } } } };\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":780,"y":280,"wires":[["ac7d59407ab07053"]]},{"id":"ac7d59407ab07053","type":"api-call-service","z":"44884235f083196f","name":"Sabse geht iPhone Torsten","server":"be07aea0.e26e6","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_antfon","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":280,"wires":[[]]},{"id":"be07aea0.e26e6","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false}]
