6.12.2025, 16:00:28] z2m: Zigbee: allowing new devices to join via FBHz Esstisch.
[6.12.2025, 16:00:28] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"device":"FBHz Esstisch","time":254},"status":"ok","transaction":"l5ov4-9"}'
[6.12.2025, 16:00:29] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/FBHz Esstisch', payload '{"backlight_mode":"always_low","child_lock":"UNLOCK","current_heating_setpoint":23.5,"factory_reset":"OFF","frost_protection":"OFF","last_seen":"2025-12-06T16:00:29+01:00","linkquality":57,"local_temperature":22.6,"local_temperature_calibration":0,"max_temperature_limit":40,"preset":"manual","running_state":"idle","sensor":"both","system_mode":"off","temperature_delta":10}'
[6.12.2025, 16:00:44] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/FBHz Esstisch', payload '{"backlight_mode":"always_low","child_lock":"UNLOCK","current_heating_setpoint":23.5,"factory_reset":"OFF","frost_protection":"OFF","last_seen":"2025-12-06T16:00:44+01:00","linkquality":60,"local_temperature":22.6,"local_temperature_calibration":0,"max_temperature_limit":40,"preset":"manual","running_state":"idle","sensor":"both","system_mode":"off","temperature_delta":10}'
[6.12.2025, 16:00:59] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/FBHz Esstisch', payload '{"backlight_mode":"always_low","child_lock":"UNLOCK","current_heating_setpoint":23.5,"factory_reset":"OFF","frost_protection":"OFF","last_seen":"2025-12-06T16:00:59+01:00","linkquality":54,"local_temperature":22.6,"local_temperature_calibration":0,"max_temperature_limit":40,"preset":"manual","running_state":"idle","sensor":"both","system_mode":"off","temperature_delta":10}'
[6.12.2025, 16:01:01] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/PM_Waschmaschine', payload '{"child_lock":"UNLOCK","countdown":null,"current":0.01,"energy":18.78,"indicator_mode":"on","last_seen":"2025-12-06T16:01:00+01:00","linkquality":63,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":241}'
[6.12.2025, 16:01:01] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/PM_Waschmaschine', payload '{"child_lock":"UNLOCK","countdown":null,"current":0.01,"energy":18.78,"indicator_mode":"on","last_seen":"2025-12-06T16:01:00+01:00","linkquality":60,"power":0,"power_outage_memory":"on","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":241}'
[6.12.2025, 16:01:02] frontend:api:bridge: Sending {"topic":"bridge/request/options","payload":{"options":{"advanced":{"log_level":"error"}},"transaction":"l5ov4-10"}}
Eigentlich keine Meldung die was aussagt. Ansosnsten ist Z2M eine ziemliche Plaudertasche und müllt das logfile voll.
