Zigbee2MQTT Aktuelle Version: 2.6.3-1 startet nicht mehr
Hallo, seit gestern, lässt sich Zigbee2MQTT nicht mehr starten. Ich verwende den folgenden Adapter: SLZB-06. Habe schon einiges versucht, Server neu gestartet, Zigbee2MQTT deinstalliert, sämtliche Updates und Firmwar auf den neusten Stand gebracht. Bin jetzt leider am Ende. Brauch eure Hilfe.
Protokolldatei mit Fehlerhinweis:
[18:00:48] INFO: Preparing to start...
[18:00:48\] INFO: Socat enabled
[18:00:48\] INFO: Starting socat
Socat startup parameters:
Options:     -d -d
Master:      pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
Slave:       tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
[18:00:49\] INFO: Starting socat process ...
2025/11/11 18:00:49 socat\[46\] N PTY is /dev/pts/0
2025/11/11 18:00:49 socat\[46\] N listening on AF=2 0.0.0.0:8485
[18:00:49\] INFO: Starting Zigbee2MQTT...
[2025-11-11 18:00:51\] info: 	z2m: Logging to console, file (filename: log.log)
[2025-11-11 18:00:51\] info: 	z2m: Starting Zigbee2MQTT version 2.6.3 (commit #unknown)
[2025-11-11 18:00:51\] info: 	z2m: Starting zigbee-herdsman (6.3.2)
[2025-11-11 18:00:51\] info: 	zh:zstack:znp: Opening TCP socket with 192.168.31.17:6638
[2025-11-11 18:00:51\] info: 	zh:zstack:znp: Socket connected
[2025-11-11 18:00:51\] info: 	zh:zstack:znp: Socket ready
[2025-11-11 18:00:51\] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-11-11 18:00:52\] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-11-11 18:01:58\] error: 	z2m: Error while starting zigbee-herdsman
[2025-11-11 18:01:58\] error: 	z2m: Failed to start zigbee-herdsman
[2025-11-11 18:01:58\] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-11-11 18:01:58\] error: 	z2m: Exiting...
[2025-11-11 18:01:58\] error: 	z2m: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms
    at Object.start (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/utils/waitress.ts:68:23)
    at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:362:31)
    at processTicksAndRejections (node:internal/process/task_queues:105:5)
    at ZnpAdapterManager.start (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:90:21)
    at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:155:16)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at Zigbee.start (/app/lib/zigbee.ts:67:27)
    at Controller.start (/app/lib/controller.ts:101:13)
    at start (/app/index.js:149:5))
    at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/zigbee-herdsman@6.3.2/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:364:23)
[18:01:59\] INFO: Preparing to start...
[18:01:59\] INFO: Socat enabled
[18:01:59\] INFO: Starting socat
Hilft dir das eventuell weiter:
Hat sich vermutlich erledigt
Hatte ich nicht gesehen… :roll_eyes:
Ich verstehe auch nicht, warum Leute hier ihre Probleme schildern aber nicht mal Bescheid geben können, wenn es sich erledigt hat
:face_vomiting:
Sorry, aber dass mit den Geräten, habe ich noch nicht gefunden. Das Zigbee wieder läuft, hatte sich überschnitten und ich hatte es noch nicht geschafft, es zu schreiben.
