Zigbee und SLZB-06P10
Hallo ich habe alles installiert bekomme aber die Meldung
[2025-02-02 21:19:11] info: 	z2m: Logging to console, file (filename: log.log)
[2025-02-02 21:19:11] info: 	z2m: Starting Zigbee2MQTT version 2.1.0 (commit #unknown)
[2025-02-02 21:19:11] info: 	z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-02 21:19:11] error: 	z2m: Error while starting zigbee-herdsman
[2025-02-02 21:19:11] error: 	z2m: Failed to start zigbee-herdsman
[2025-02-02 21:19:11] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-02 21:19:11] error: 	z2m: Exiting...
[2025-02-02 21:19:11] error: 	z2m: Error: USB adapter discovery error (No valid USB adapter found). Specify valid 'adapter' and 'port' in your configuration.
    at discoverAdapter (/app/node_modules/.pnpm/zigbee-herdsman@3.2.5/node_modules/zigbee-herdsman/src/adapter/adapterDiscovery.ts:523:15)
    at processTicksAndRejections (node:internal/process/task_queues:105:5)
    at Function.create (/app/node_modules/.pnpm/zigbee-herdsman@3.2.5/node_modules/zigbee-herdsman/src/adapter/adapter.ts:68:33)
    at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.5/node_modules/zigbee-herdsman/src/controller/controller.ts:132:24)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:142:13)
    at start (/app/index.js:161:5)
[2025-02-02 21:19:11] error: 	z2m: If this happens after updating to Zigbee2MQTT 2.0.0, see https://github.com/Koenkk/zigbee2mqtt/discussions/24364
nutze den SLZB-06 … …
