Wieder einmal Diehl Wasserzähler mit IZAR RC868 R4 Funksender auslesen
Ich schaffe es einfach nicht meine Watermeter id auszulesen, hat jemand ein Script das funktioniert?monentan hab ich das, das liefert den WLAN Status usw aber keine Watermeter id bitte um hilfe.
## WMBUS METER az-delivery-devkit-v4 + CC1101 for Diehl IZAR RC 868 I R4 PL
## Hardware: ESP32 240MHz, 520KB RAM, 4MB Flash
## this version shows all watermeters. Use this for the first test
substitutions:
  ## device settings
  device_name_short: "water-meter-esp"
  device_description: "Wasserzähler ESP32, CUL - CC1101, IZAR module (Diehl IZAR RC 868 I R4 PL (SzczepanLeon) - all watermeters"
  projectname: "Diehl IZAR RC 868.Watermeter"
  appversion: "3.0.0"
  ## all watermeters   wmid: "0"
  ## your watermeter: wmid: !secret watermeterId
  wmid: "0"
  ## logger settings
  log_level: "DEBUG" # not that logging need memory, so in production mode use "WARN"
  log_wmbus: "DEBUG" # Loglevel for wmbus meters component
  log_baudrate: "0" # 0 disable uart logger messages
## APPLICATION ESPHOME
esphome:
  comment: ${device_description}
  # Automatically add the mac address to the name
  # so you can use a single firmware for all devices
  name_add_mac_suffix: false
  project:
    version: ${appversion}
  build_path: ./build/${device_name_short}
  on_boot:
    then:
      - globals.set:
          value: !lambda "return id(boot_counter)+=1;"
      - logger.log:
          level: INFO
          tag: "system"
          format: "BOOTMESSAGE:${device_name_short} API is connected, Device ready!"
      - component.update: bootcounter
  on_shutdown:
    then:
      - logger.log:
          level: ERROR
          tag: "system"
          format: "BOOTMESSAGE:${device_name_short} is down!"
## HARDWARE az-delivery-devkit-v4
##          ESP32 240MHz, 520KB RAM, 4MB Flash
esp32:
  board: az-delivery-devkit-v4
  framework:
    type: arduino
## EXTERNAL COMPONENTS
## https://esphome.io/components/external_components.html
external_components:
  # uses the version 3 from SzczepanLeon (github)
  # https://github.com/SzczepanLeon/esphome-components
  # You can make ESPHome check the repository every time by setting this option to 0s
  - source: github://SzczepanLeon/esphome-components@version_3
    refresh: 0s
    components: [wmbus]
## Global variables
globals:
  - id: boot_counter
    type: int
    restore_value: yes
    initial_value: "0"
  - id: last_value
    type: float
    restore_value: yes
    initial_value: "0.00"
  - id: alarm_error_text
    type: std::vector<std::string>
    restore_value: no
    initial_value: '{"no error", "general_alarm","leakage","meter_blocked","back_flow","underflow","overflow","submarine","sensor_fraud","mechanical_fraud"}'
## WIFI Settings 3 wifis
wifi:
  networks:
    - ssid: !secret ssid3_name
      password: !secret ssid3_pswd
      priority: 0
    - ssid: !secret ssid1_name
      password: !secret ssid1_pswd
      priority: 1
    - ssid: !secret ssid2_name
      password: !secret ssid2_pswd
      priority: 2
  domain: !secret domain
  manual_ip:
    static_ip: 192.168.1.55
    gateway: 192.168.1.1
    subnet: 255.255.255.0
## mDNS Component
mdns:
  # if mDNS is disabled, they will no longer be able to automatically find your devices.
  disabled: false
## The captive portal component in ESPHome is a
## fallback mechanism for when connecting to the
## configured WiFi fails.
captive_portal:
## LOGGER COMPONENT
logger:
  level: ${log_level}
  baud_rate: ${log_baudrate}
  logs:
    wmbus: ${log_wmbus}
    wMBus-lib: ${log_wmbus}
## OTA COMPONENT
ota:
  password: !secret ota_pswd
  platform: esphome
  on_begin:
    then:
      - logger.log:
          format: "OTA Start"
          tag: "OTA"
          level: WARN
  on_progress:
    then:
      - logger.log:
          level: WARN
          tag: "OTA"
          format: "OTA progress %0.1f%%"
          args: ["x"]
  on_end:
    then:
      - logger.log:
          format: "OTA End"
          tag: "OTA"
          level: WARN
  on_error:
    then:
      - logger.log:
          format: "OTA update error %d"
          tag: "OTA"
          level: ERROR
          args: ["x"]
## COMPONENT WEBSERVER
web_server:
  port: 80
  version: 2
  js_url: !secret webserver_jsurl
## Home Assistant API COMPONENT
api:
  port: 6053
  reboot_timeout: 0s
## SNTP COMPONENT
time:
  - platform: sntp
    timezone: Europe/Berlin
    servers:
      - 0.at.pool.ntp.org
      - 0.pool.ntp.org
      - 1.pool.ntp.org
    on_time_sync:
      then:
        - logger.log:
            tag: "system"
            level: INFO
            format: "Synchronized sntp clock"
##           WMBUS CC1101 --> ESP32 az-delivery-devkit-v4
##                                                               o 1 (3.3V)
##   ╭――x――x――x――x――x――x――x――x――x――x――x――x――x――x――x――x――x――x――x――o―╮
## - | 5v               az-delivery-devkit-v4                      | -- ANT
##   |                          16 17 5  18 19               23    |
##   ╰――x――x――x――x――x――x――x――x――o――x――o――o――o――o――o――o――o――o――o――o―╯
##                              o  |  |  o  |                 |   ╰-o - 2 (GND)
##                              7  o  |  4  o                 o
##                            GDO0 6  | CLK 5                 3
##                               GD02 o    MISO              M0SI
##                                    8
##                                   CSN
wmbus:
  mosi_pin: GPIO23 ## SI:   braun
  miso_pin: GPIO19 ## SO:   grün
  clk_pin: GPIO18 ## SCLK: violett
  cs_pin: GPIO05 ## CSN:  orange
  gdo0_pin: GPIO16 ## GD00: gelb (rx)
  gdo2_pin: GPIO17 ## GD02: weiss (tx)
  # log_unknown (Optional): Show telegrams from not configured meters in log.
  # Defaults to False
  log_unknown: True
## SWITCHES
switch:
  # reset boot counter value
  - platform: template
    name: Device Boot Counter reset
    turn_on_action:
      then:
        - lambda: |-
            id(boot_counter) = 0;
            id(bootcounter).publish_state(id(boot_counter));
        - logger.log:
            level: WARN
            tag: "system"
            format: "${device_name_short} reset boot counter o.k!"
  - platform: safe_mode
    name: "Device Restart (Safe Mode)"
  - platform: restart
  - platform: factory_reset
    name: Device Restart Factory
## SENSORS
sensor:
  - platform: wmbus
    # Meter ID (usually from sticker). Can be specified as decimal or hex.
    # only hex is working for my watermeter !
    # see: https://github.com/SzczepanLeon/esphome-components/issues/6
    # edit watermeterid in the secrets file
    meter_id: ${wmid}
    type: izar
    add_prefix: true
    # The LQI value reported by the CC1101 is a 7 bit unsigned number with a range from 0 to 127.
    # Note that a lower value indicates a better link.
    # The LQI of a received packet will be bad (higher number) when there is lot of interference.
    lqi:
      name: "Watermeter CC1101 LQI"
      unit_of_measurement: "lqi"
      entity_category: "diagnostic"
    # The RSSI value reported by the CC1101 is a 8 bit signed number with an effective
    # range from -138 dBm to -10.5 dBm when the CC1101 is operating around 868 MHz.
    # RSSI stands for received signal strength (power) indication (in dBm).
    # A higher value indicates higher power.
    rssi:
      name: "Watermeter CC1101 RSSI"
      unit_of_measurement: "%"
    # reports the watermeter display value
    total_water_m3:
      unit_of_measurement: "m³"
      state_class: total_increasing
      device_class: "water"
      accuracy_decimals: 3
      icon: mdi:counter
      # update and calulatet all watermeter data values
      on_value:
        then:
          - lambda: |-
              ESP_LOGI("wmbus", "Water Display value: %.3f, last value: %.3f", id(waterdisplay).state, id(last_value));
              id(last_value)=id(waterdisplay).state;
    # get the last month total watermter m3 from the wmbus telegram  (wM-Bus 2.1.10)
    last_month_total_water_m3:
      name: "Water last month"
      icon: mdi:counter
    # water current month (wM-Bus v2.1.4)
    current_month_total_water_l:
      name: "Water current month"
      accuracy_decimals: 2
      unit_of_measurement: "L"
    # get the battery life time (wM-Bus v2.1.4)
    remaining_battery_life_y:
      name: "Watermeter Battery Life"
      unit_of_measurement: "Years"
      icon: mdi:battery
    # get the last transmit periode (wM-Bus v2.1.4)
    transmit_period_s:
      name: "Watermeter transmit periode"
      unit_of_measurement: "sec"
      icon: mdi:timelapse
    ## get the current watermeter alarms and publish the text message (wM-Bus 2.1.10)
    current_alarms:
      name: "Watermeter current alarm code"
      icon: mdi:alarm-light
    ## get the prevois watermeter alarms and publish the text message (wM-Bus 2.1.10)
    previous_alarms:
      name: "Watermeter pervious alarm code"
  # Wifi quality RSSI, internal used to calculate the Wifi quality RSSI in percentage
  - platform: wifi_signal
    update_interval: 60s
    internal: true
    disabled_by_default: true
  # Wifi quality RSSI in percentage
  # Received Signal Strength (RSSI) is a measure of incoherent
  ## (raw) RF power in a channel.
  - platform: copy # Reports the WiFi signal strength in %
    source_id: wifi_signal_db
    name: "Device WLAN Signal"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
  # device boot counter
    name: Device Boot counter
    icon: mdi:counter
    accuracy_decimals: 0
    state_class: "measurement"
    lambda: return (id(boot_counter));
