Abend ,
ich habe mir eine Filter gebaut um die jeweilige min und max Zelle in meinem 16S Akku auszulesen. Jetzt möchte ich gern die Nachricht an einen Call Service übergeben, allerdings finde ich nicht die richtige Domain. In der Nachricht enthalten ist die Topic–> Zellnummer und Payload–> Zellspannung enthalten. Is es möglich es mit einem CallService zu lösen der die Topic und Payload hintereinander ausgibt? Im Data hab ich schon bissel rumgespielt aber keinen Erfolg bis jetzt gehabt es richtig zu formatieren.
Ich hoffe ich konnte mich verständlich ausdrücken ![]()
Grüße
flow {"id":"21c741011f1f661b","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle1","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell1","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":80,"wires":[["8e10e63086caefc6"]]},{"id":"8e10e63086caefc6","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":" Zelle 1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":80,"wires":[["3389e75f4f895335"]]},{"id":"add417d17f512749","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":140,"wires":[["3389e75f4f895335"]]},{"id":"0f21f26c687ca1ea","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":200,"wires":[["3389e75f4f895335"]]},{"id":"d2a6987cdbe36ee1","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 4","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":260,"wires":[["3389e75f4f895335"]]},{"id":"345552cf3bfe3162","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 5","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":320,"wires":[["3389e75f4f895335"]]},{"id":"49d247006ce71362","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":380,"wires":[["3389e75f4f895335"]]},{"id":"a073a813f10bc2eb","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 7","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":440,"wires":[["3389e75f4f895335"]]},{"id":"47a980adf4e247e7","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 8","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":500,"wires":[["3389e75f4f895335"]]},{"id":"9e12e7d53e48ecdf","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 9","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":560,"wires":[["3389e75f4f895335"]]},{"id":"51dde36ff6ea3a8b","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 10","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":600,"wires":[["3389e75f4f895335"]]},{"id":"b46cee4a39d4524e","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 11","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":660,"wires":[["3389e75f4f895335"]]},{"id":"05e5f1ea4c3932c1","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 12","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":720,"wires":[["3389e75f4f895335"]]},{"id":"b7517cb6a4b7c017","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 13","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":780,"wires":[["3389e75f4f895335"]]},{"id":"e32b5ae49ffaee71","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Zelle 14","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":840,"wires":[["3389e75f4f895335"]]},{"id":"8a51aad747166efe","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":" Zelle 15","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":900,"wires":[["3389e75f4f895335"]]},{"id":"9e06dd70fedf3237","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":" Zelle 16","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":960,"wires":[["3389e75f4f895335"]]},{"id":"9229cd62a0526d4f","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle2","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell2","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":140,"wires":[["add417d17f512749"]]},{"id":"be342ce95aca7eca","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle3","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell3","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":200,"wires":[["0f21f26c687ca1ea"]]},{"id":"a299169b33437548","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle4","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell4","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":260,"wires":[["d2a6987cdbe36ee1"]]},{"id":"4a92bde2ac5ec41b","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle5","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell5","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":320,"wires":[["345552cf3bfe3162"]]},{"id":"67732f34ef2e0198","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle6","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell6","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":380,"wires":[["49d247006ce71362"]]},{"id":"3182125542a350f8","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle7","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell7","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":440,"wires":[["a073a813f10bc2eb"]]},{"id":"35a53c5bfbebacd6","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle8","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell8","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":500,"wires":[["47a980adf4e247e7"]]},{"id":"87e6b10e36fcc066","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle9","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell9","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":560,"wires":[["9e12e7d53e48ecdf"]]},{"id":"b1e7968f3f29626d","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle10","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell10","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":620,"wires":[["51dde36ff6ea3a8b"]]},{"id":"ec9ea18e6b1123ba","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle11","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell11","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":680,"wires":[["b46cee4a39d4524e"]]},{"id":"da80a5706498a257","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle12","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell12","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":740,"wires":[["05e5f1ea4c3932c1"]]},{"id":"288ec42e938be259","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle13","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell13","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":800,"wires":[["b7517cb6a4b7c017"]]},{"id":"2d8a60969ab4eaeb","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle14","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell14","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":860,"wires":[["e32b5ae49ffaee71"]]},{"id":"4f94dc72f38d5ccd","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle15","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell15","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":920,"wires":[["8a51aad747166efe"]]},{"id":"c71b3d4f822cae4b","type":"mqtt in","z":"495effdafbe867b1","name":"Zelle16","topic":"N/b827eb0afbf2/battery/1/Voltages/Cell16","qos":"0","datatype":"auto-detect","broker":"f85656a734810fc9","nl":false,"rap":true,"rh":0,"inputs":0,"x":70,"y":980,"wires":[["9e06dd70fedf3237"]]},{"id":"3389e75f4f895335","type":"change","z":"495effdafbe867b1","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"msg.payload.value","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"$round(payload,4)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":320,"wires":[["360832b93e73f893","3a0eb0673d26dbf6"]]},{"id":"360832b93e73f893","type":"smooth","z":"495effdafbe867b1","name":"Min","property":"payload","action":"min","count":"16","round":"3","mult":"single","reduce":true,"x":710,"y":300,"wires":[["798433355235209e"]]},{"id":"3a0eb0673d26dbf6","type":"smooth","z":"495effdafbe867b1","name":"Max","property":"payload","action":"max","count":"16","round":"3","mult":"single","reduce":true,"x":710,"y":380,"wires":[["a013746779a2d8a9","40aa5f06ea0b45cd"]]},{"id":"a013746779a2d8a9","type":"delay","z":"495effdafbe867b1","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"10","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":930,"y":380,"wires":[["8bd430f8a96885c0"]]},{"id":"798433355235209e","type":"delay","z":"495effdafbe867b1","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"10","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":930,"y":300,"wires":[[]]},{"id":"739b01b70bbcb12f","type":"comment","z":"495effdafbe867b1","name":"Call Service für MIN","info":"","x":1150,"y":300,"wires":[]},{"id":"b914dd0f239bc2e0","type":"comment","z":"495effdafbe867b1","name":"Call Service für MAX","info":"","x":1160,"y":380,"wires":[]},{"id":"f85656a734810fc9","type":"mqtt-broker","name":"victorn wlan","broker":"192.168.0.122","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
