Updates für Integrationen werden nichtmehr angezeigt
leider habe ich das Problem das mir Updates für alle Integrationen nichmehr angezeigt werden und ich somit keine Updates installieren kann.
System VM unter Proxmox
Neustart von allen Komponenten inkl. Server ist mehrfach erfolgt.
Systemübersicht (Auszug)
"home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2025.5.3",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.13.3",
    "docker": true,
    "arch": "x86_64",
    "timezone": "Europe/Berlin",
    "os_name": "Linux",
    "os_version": "6.12.23-haos",
    "supervisor": "2025.05.3",
    "host_os": "Home Assistant OS 15.2",
    "docker_version": "28.0.4",
    "chassis": "vm",
    "run_as_root": true
  "custom_components": {
    "hacs": {
      "documentation": "https://hacs.xyz/docs/use/",
      "version": "2.0.5",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "unifi_access": {
      "documentation": "https://www.home-assistant.io/integrations/unifi_access",
      "version": "1.2.5",
      "requirements": [
        "websocket-client==1.8.0"
    "alphaess": {
      "documentation": "https://github.com/CharlesGillanders/homeassistant-alphaESS",
      "version": "0.5.7",
      "requirements": [
        "alphaessopenapi==0.0.11"
    "garmin_connect": {
      "documentation": "https://github.com/cyberjunky/home-assistant-garmin_connect",
      "version": "0.2.26",
      "requirements": [
        "garminconnect>=0.2.24",
        "tzlocal"
    "nodered": {
      "documentation": "https://zachowj.github.io/node-red-contrib-home-assistant-websocket/guide/custom_integration/",
      "version": "4.1.2",
      "requirements": []
    "powercalc": {
      "documentation": "https://docs.powercalc.nl",
      "version": "v1.16.7",
      "requirements": [
        "numpy>=1.21.1"
    "alexa_media": {
      "documentation": "https://github.com/alandtse/alexa_media_player/wiki",
      "version": "5.3.0",
      "requirements": [
        "alexapy==1.29.5",
        "packaging>=20.3",
        "wrapt>=1.14.0"
    "waste_collection_schedule": {
      "documentation": "https://github.com/mampfes/hacs_waste_collection_schedule#readme",
      "version": "2.5.0",
      "requirements": [
        "icalendar",
        "recurring_ical_events",
        "icalevents>=0.1.26,!=0.1.28",
        "beautifulsoup4",
        "lxml",
        "pycryptodome"
    "better_thermostat": {
      "documentation": "https://github.com/KartoffelToby/better_thermostat",
      "version": "1.6.1",
      "requirements": []
Geht es hier um die Anzeige von Updates durch HA, oder um die Anzeige von HACS Updates, sprich um das?
VG JIm
Leider um beides, es werden keinerlei Updates für Integrationen mehr angezeigt egal ob von hacs oder dem offiziellen repo
  • Browser Cache einmal leeren, vielleicht ist da der Wurm drin.
  • Einen anderen Browser versuchen
  • Browser im Inkognito-Modus nutzen
OK so spontan würde mir da ggf. ein IP- und/oder DNS-Problem einfallen, sodass HACS bzw. HA irgendwelche Server nicht erreichen kann über die dann irgendwelche Versions-Nr. von Integrationen abgeglichen werden. D.h. ich würde mal in diese Richtung suchen. Z.B. was wo für DNS-Server eingetragen sind, oder ob irgendwelche “Blocker” wie PiHole, AdGuard usw. ggf. irgendetwas blocken.
alles versucht, bringt aber nichts
Hast du die Logs von HA mal durchgesehen?
Kannst Du neue, beliebige Integrationen installieren, bzw. bekommst Du die angezeigt? Falls nein, würde das für die Vermutung von @Jim_OS sprechen bzw. Netzwerk.
