2024-05-16 16:16:28.647 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'device_tracker' from integration tado has a non string unique_id '6596853', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+tado%22
2024-05-16 16:16:28.800 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration battery_notes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.801 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration magic_areas which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.803 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.804 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration fordpass which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.805 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration spook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.807 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration apple_airplayer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.809 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.811 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ical which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.818 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration icloud3 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.821 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration email which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.824 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration smart_irrigation which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.825 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hon which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.831 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration dwains_dashboard which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.833 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.836 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration multizone_controller which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.839 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration thermal_comfort which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.842 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration dash_cast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.845 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration pool_pump which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.849 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.854 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.857 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.860 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration tgtg which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.862 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.864 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration tuya_local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.867 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.869 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration spook_inverse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.871 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ics_calendar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.873 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.875 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.877 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration switch_manager which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.879 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ryd which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.881 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration nuki_ng which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.883 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.884 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.886 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ics which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.887 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration waste_collection_schedule which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.889 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration cloudflare_tunnel_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:28.891 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-16 16:16:29.713 WARNING (MainThread) [homeassistant.helpers.config_validation] The 'purge_interval' option near /config/configuration.yaml:31 is deprecated, please remove it from your configuration
2024-05-16 16:16:32.963 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'waste_collection_schedule' at custom_components/waste_collection_schedule/waste_collection_schedule/source_shell.py, line 188: source_module = importlib.import_module( (offender: /config/custom_components/waste_collection_schedule/waste_collection_schedule/source_shell.py, line 188: source_module = importlib.import_module(), please report it to the author of the 'waste_collection_schedule' custom integration
2024-05-16 16:16:37.991 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from webrtc, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'webrtc' custom integration
2024-05-16 16:16:38.001 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] ServiceCallType was used from webrtc, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.ServiceCall instead, please report it to the author of the 'webrtc' custom integration
2024-05-16 16:16:38.728 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from watchman, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'watchman' custom integration
2024-05-16 16:16:41.636 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'thermal_comfort' accesses hass.helpers.service. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from service directly at custom_components/thermal_comfort/__init__.py, line 162: hass.helpers.service.async_register_admin_service(, please create a bug report at https://github.com/dolezsa/thermal_comfort/issues
2024-05-16 16:16:46.541 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:16:52.211 ERROR (MainThread) [homeassistant.components.script] Script with alias 'Vorheizen starten' failed to setup actions and has been disabled: Unknown device 'ed649d47b5c795232dafdeeafd0cba05'
2024-05-16 16:16:52.653 WARNING (MainThread) [homeassistant.setup] Setup of telegram_bot is taking over 10 seconds.
2024-05-16 16:16:52.783 WARNING (MainThread) [custom_components.fordpass] 403 Client Error: Forbidden for url: https://login.ford.ie/4566605f-43a7-400a-946e-89cc9fdb0bd7/B2C_1A_SignInSignUp_EN-IE/SelfAsserted?tx=StateProperties=eyJUSUQiOiJlYTk3NmM1NS0wNjZhLTQzMmItYTA3Yy05MWYyZWRlN2JlNjkifQ&p=B2C_1A_SignInSignUp_EN-IE
2024-05-16 16:16:52.784 WARNING (MainThread) [custom_components.fordpass] Error communicating with FordPass for WF0PXXGCHPPL88503
2024-05-16 16:16:52.786 WARNING (MainThread) [custom_components.fordpass] Returning Stale data to prevent unavaliable status
2024-05-16 16:16:52.788 ERROR (MainThread) [custom_components.fordpass] Error fetching fordpass data: Error communicating with FordPass for WF0PXXGCHPPL88503
2024-05-16 16:16:55.178 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'hon' at custom_components/hon/__init__.py, line 41: hon = await Hon(**kwargs).create() (offender: /usr/local/lib/python3.12/site-packages/pyhon/appliance.py, line 48: self._extra: Optional[ApplianceBase] = importlib.import_module(), please create a bug report at https://github.com/Andre0512/hon/issues
2024-05-16 16:16:57.111 WARNING (MainThread) [homeassistant.components.renault.renault_vehicle] Ignoring endpoint VF1AG000368602321 res_state as it is denied: This endpoint is denied: ('err.func.403', 'Access is denied for this resource')
2024-05-16 16:16:59.533 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-05-16 16:16:59.571 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'smart_irrigation' at custom_components/smart_irrigation/helpers.py, line 436: mod = importlib.import_module( (offender: /config/custom_components/smart_irrigation/helpers.py, line 436: mod = importlib.import_module(), please create a bug report at https://github.com/jeroenterheerdt/HASmartIrrigation/issues
2024-05-16 16:16:59.596 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'smart_irrigation' at custom_components/smart_irrigation/helpers.py, line 436: mod = importlib.import_module( (offender: /config/custom_components/smart_irrigation/helpers.py, line 436: mod = importlib.import_module(), please create a bug report at https://github.com/jeroenterheerdt/HASmartIrrigation/issues
2024-05-16 16:16:59.628 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'smart_irrigation' at custom_components/smart_irrigation/helpers.py, line 436: mod = importlib.import_module( (offender: /config/custom_components/smart_irrigation/helpers.py, line 436: mod = importlib.import_module(), please create a bug report at https://github.com/jeroenterheerdt/HASmartIrrigation/issues
2024-05-16 16:17:03.050 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'meross_lan' at custom_components/meross_lan/__init__.py, line 566: module = import_module( (offender: /config/custom_components/meross_lan/__init__.py, line 566: module = import_module(), please create a bug report at https://github.com/krahabb/meross_lan/issues
2024-05-16 16:17:03.089 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'meross_lan' at custom_components/meross_lan/meross_device.py, line 472: module = import_module( (offender: /config/custom_components/meross_lan/meross_device.py, line 472: module = import_module(), please create a bug report at https://github.com/krahabb/meross_lan/issues
2024-05-16 16:17:03.107 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module inside the event loop by custom integration 'meross_lan' at custom_components/meross_lan/meross_device.py, line 472: module = import_module( (offender: /config/custom_components/meross_lan/meross_device.py, line 472: module = import_module(), please create a bug report at https://github.com/krahabb/meross_lan/issues
2024-05-16 16:17:03.570 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:03.605 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:03.671 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:03.702 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:03.732 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:03.786 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:03.863 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:03.947 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:04.024 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:04.091 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:04.161 WARNING (ImportExecutor_0) [homeassistant.helpers.typing] HomeAssistantType was used from hon, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the 'hon' custom integration
2024-05-16 16:17:04.593 WARNING (MainThread) [homeassistant.components.light] light.luftreiniger_licht (<class 'custom_components.hon.light.HonLightEntity'>) does not report a color mode, this will stop working in Home Assistant Core 2025.3, please create a bug report at https://github.com/Andre0512/hon/issues
2024-05-16 16:17:11.303 WARNING (MainThread) [homeassistant.helpers.entity] Entity apple_airplayer.airplay_f0b3ec66cdd2 (<class 'custom_components.apple_airplayer.media_player.AirPlayer'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <MediaPlayerEntityFeature.VOLUME_SET|TURN_ON|TURN_OFF|PLAY_MEDIA|VOLUME_STEP: 1924>, please create a bug report at https://github.com/georgezhao2010/apple_airplayer/issue and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-05-16 16:17:12.095 WARNING (MainThread) [homeassistant.helpers.entity] Entity apple_airplayer.airplay_f434f03d842e (<class 'custom_components.apple_airplayer.media_player.AirPlayer'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <MediaPlayerEntityFeature.VOLUME_SET|TURN_ON|TURN_OFF|PLAY_MEDIA|VOLUME_STEP: 1924>, please create a bug report at https://github.com/georgezhao2010/apple_airplayer/issue and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-05-16 16:17:33.068 WARNING (MainThread) [homeassistant.components.media_player] Updating webostv media_player took longer than the scheduled update interval 0:00:10
2024-05-16 16:17:33.068 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.tv_wohnzimmer is taking over 10 seconds
2024-05-16 16:17:33.069 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.lg_webos_smart_tv is taking over 10 seconds
2024-05-16 16:17:33.169 WARNING (MainThread) [homeassistant.components.apple_tv] Connection lost to Apple TV "AppleTV"
2024-05-16 16:17:37.160 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fernbedienung_nische_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.160 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.tuerkontakt_haustuer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fensterkontakt_badezimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fensterkontakt_esszimmer_1_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fensterkontakt_esszimmer_2_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fensterkontakt_kueche_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fensterkontakt_schlafzimmer_1_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fensterkontakt_schlafzimmer_2_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.lichtschalter_treppe_oben_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.schalter_garagentor_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.161 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fernbedienung_esszimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.fernbedienung_wohnzimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.lichtschalter_esszimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.lichtschalter_kueche_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.lichtschalter_treppe_unten_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.bewegungsmelder_eingang_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.bewegungsmelder_keller_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.bewegungsmelder_garage_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.162 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.temperatursensor_keller_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.temperatursensor_kueche_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.rauchwarnmelder_esszimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.bewegungsmelder_badezimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.rauchwarnmelder_wohnzimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.rauchwarnmelder_waschkueche_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.temperatursensor_badezimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.temperatursensor_wohnzimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.temperatursensor_schlafzimmer_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.163 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.temperatursensor_strassenseite_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.164 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.temperatursensor_schlafzimmer_fynn_battery with value unknown excluded from calculation in sensor.batterien
2024-05-16 16:17:37.244 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.helpers.event. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from event directly at custom_components/hacs/base.py, line 642: self.hass.helpers.event.async_track_time_interval(, please create a bug report at https://github.com/hacs/integration/issues
2024-05-16 16:19:57.638 ERROR (MainThread) [custom_components.watchman.utils] Unable to parse /config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/custom_components/tuya_local/devices/awow_th213_thermostat.yaml: [Errno 40] Symbolic link loop: '/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/custom_components/tuya_local/devices/awow_th213_thermostat.yaml'
2024-05-16 16:20:16.787 ERROR (MainThread) [custom_components.watchman.utils] Unable to parse /config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/custom_components/tuya_local/devices/bstuokey_access_keypad.yaml: [Errno 40] Symbolic link loop: '/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/config/custom_components/tuya_local/devices/bstuokey_access_keypad.yaml'
2024-05-16 16:23:54.417 WARNING (MainThread) [custom_components.fordpass]
2024-05-16 16:23:54.417 WARNING (MainThread) [custom_components.fordpass] Error communicating with FordPass for WF0PXXGCHPPL88503
2024-05-16 16:23:54.418 WARNING (MainThread) [custom_components.fordpass] Returning Stale data to prevent unavaliable status
2024-05-16 16:23:54.418 ERROR (MainThread) [custom_components.fordpass] Error fetching fordpass data: Error communicating with FordPass for WF0PXXGCHPPL88503
2024-05-16 16:23:54.739 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:23:55.006 WARNING (MainThread) [homeassistant.components.apple_tv] Connection lost to Apple TV "AppleTV"
2024-05-16 16:23:55.342 ERROR (MainThread) [homeassistant.components.meater] Timeout fetching meater_api data
2024-05-16 16:23:55.364 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2024-05-16 16:23:55.365 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 715, in ping
await self._send_frame(message, WSMsgType.PING)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 675, in _send_frame
self._write(header + mask + message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 702, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2024-05-16 16:23:55.390 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-05-16 16:23:56.757 WARNING (MainThread) [deebot_client.mqtt_client] Connection lost; Reconnecting in 5 seconds ...
File "/usr/local/lib/python3.12/site-packages/deebot_client/mqtt_client.py", line 203, in mqtt
async with await self._get_client() as client:
File "/usr/local/lib/python3.12/site-packages/aiomqtt/client.py", line 729, in __aexit__
raise exc
aiomqtt.exceptions.MqttCodeError: [code:7] The connection was lost.
2024-05-16 16:23:57.986 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:23:58.704 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 88, in ban_middleware
File "/usr/local/lib/python3.12/site-packages/aiohttp_session/__init__.py", line 199, in factory
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 295, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 53, in get
return await WebSocketHandler(request.app[KEY_HASS], request).async_handle()
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 286, in async_handle
await wsock.prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 152, in prepare
payload_writer = await super().prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 417, in prepare
return await self._start(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 425, in _start
await self._write_headers()
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 505, in _write_headers
await writer.write_headers(status_line, self._headers)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 130, in write_headers
self._write(buf)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 75, in _write
2024-05-16 16:23:59.009 ERROR (MainThread) [aiohttp.server] Error handling request
self._write(buf)
2024-05-16 16:23:59.582 ERROR (MainThread) [aiohttp.server] Error handling request
self._write(buf)
2024-05-16 16:24:01.144 ERROR (MainThread) [paho.mqtt.client] failed to receive on socket: [Errno 32] Broken pipe
2024-05-16 16:24:01.149 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.lichtschalter_badezimmer_battery with value unavailable excluded from calculation in sensor.batterien
2024-05-16 16:24:02.659 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.rauchwarnmelder_waschkueche_battery with value unavailable excluded from calculation in sensor.batterien
2024-05-16 16:24:02.686 WARNING (MainThread) [homeassistant.components.group.sensor] Unable to use state. Only numerical states are supported, entity sensor.bewegungsmelder_badezimmer_battery with value unavailable excluded from calculation in sensor.batterien
2024-05-16 16:24:02.781 WARNING (MainThread) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-05-16 16:24:03.753 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:03.762 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:03.781 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:03.792 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:03.803 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:03.805 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.193 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.195 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.197 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.199 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.201 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.263 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.265 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.282 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.288 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.290 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.293 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.295 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.297 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.299 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.302 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.307 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.309 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.322 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.325 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.329 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.332 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.338 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.345 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.347 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.351 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.353 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.364 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.366 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.368 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.370 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.371 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.378 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.383 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.385 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.388 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.391 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.393 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.400 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.402 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.404 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.406 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.410 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.413 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.414 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.415 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.418 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.422 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.424 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.426 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.428 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.431 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.432 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.434 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.437 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.439 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.441 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.443 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.445 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.446 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.448 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.449 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.452 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.453 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.455 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.457 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.459 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.461 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.463 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.465 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.466 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.469 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.472 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.474 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.476 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.478 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.480 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.484 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.500 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.502 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.504 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.507 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.508 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.510 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.513 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.517 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.519 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.520 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.762 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-05-16 16:24:04.762 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.tv_esszimmer is taking over 10 seconds
2024-05-16 16:24:04.771 ERROR (MainThread) [homeassistant.components.nina] Timeout fetching nina data
2024-05-16 16:24:04.829 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.842 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:04.844 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:07.312 WARNING (MainThread) [custom_components.fordpass] 403 Client Error: Forbidden for url: https://login.ford.ie/4566605f-43a7-400a-946e-89cc9fdb0bd7/B2C_1A_SignInSignUp_EN-IE/SelfAsserted?tx=StateProperties=eyJUSUQiOiI4OTU1OTVmZi1hYzViLTQ4YzYtYWU1Zi1mNTIwOWJhYmZjOGEifQ&p=B2C_1A_SignInSignUp_EN-IE
2024-05-16 16:24:07.312 WARNING (MainThread) [custom_components.fordpass] Error communicating with FordPass for WF0PXXGCHPPL88503
2024-05-16 16:24:07.312 WARNING (MainThread) [custom_components.fordpass] Returning Stale data to prevent unavaliable status
2024-05-16 16:24:07.312 ERROR (MainThread) [custom_components.fordpass] Error fetching fordpass data: Error communicating with FordPass for WF0PXXGCHPPL88503
2024-05-16 16:24:08.003 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:08.031 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:08.630 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:08.632 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:10.847 WARNING (MainThread) [homeassistant.components.mqtt.client] No ACK from MQTT server in 10 seconds (mid: 4)
2024-05-16 16:24:11.022 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.tuerklingel_sub] Error from stream worker: Error demuxing stream while finding first packet: [Errno 110] Operation timed out: 'rtsp://admin:A15bimdS%21@192.168.178.74:554/Preview_01_sub'
2024-05-16 16:24:11.335 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.350 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.382 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.396 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.410 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.431 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.450 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.497 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.520 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.547 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.577 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.611 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.625 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.645 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.667 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.689 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.720 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.728 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.755 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.772 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.798 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.806 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.821 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.842 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.856 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.892 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.922 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.942 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.956 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:11.971 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.024 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.025 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.033 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.045 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.064 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.092 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.106 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.138 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.166 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.186 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.206 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.214 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.230 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.260 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.280 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.297 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.316 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.342 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.366 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.368 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.384 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.405 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.406 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.430 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.437 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.453 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.472 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.489 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.513 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.527 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.547 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.554 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.574 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.597 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.612 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.637 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.665 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.690 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.720 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.746 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.767 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.780 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.802 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.829 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.837 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.850 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.876 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.885 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:12.909 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:17.011 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:17.024 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:17.049 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:17.312 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:17.313 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:17.334 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-05-16 16:24:19.030 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.watchman_missing_entities exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
