Scene aktivieren schlägt fehl
Hallo, ich habe habe mir eine Scene erstellt damit ich bspw alle Rolläden im Obergeschoss schließen kann. Sobald ich die Scene aktivieren bekomme ich eine Fehlermeldung und nicht alle Rolläden fahren runter. Erst beim zweiten betätigen fahren die restlichen runter. Hoffe jmd kann helfen.
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/wiser/cover.py:200
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 15:32:01 (1 occurrences)
Last logged: 15:32:01
[139643355903680] [Errno 104] Connection reset by peer
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 227, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1969, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2006, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
    return await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 870, in entity_service_call
    response_data = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 942, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/scene/__init__.py", line 114, in _async_activate
    await self.async_activate(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 334, in async_activate
    await async_reproduce_state(
  File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 67, in async_reproduce_state
    await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 61, in worker
    await platform.async_reproduce_states(
  File "/usr/src/homeassistant/homeassistant/components/cover/reproduce_state.py", line 125, in async_reproduce_states
  File "/usr/src/homeassistant/homeassistant/components/cover/reproduce_state.py", line 86, in _async_reproduce_state
    result = await task
  File "/config/custom_components/wiser/cover.py", line 200, in async_close_cover
    await self._device.close()
  File "/usr/local/lib/python3.11/site-packages/aioWiserHeatAPI/shutter.py", line 179, in close
    return await self._send_command(
  File "/usr/local/lib/python3.11/site-packages/aioWiserHeatAPI/shutter.py", line 64, in _send_command
    result = await self._wiser_rest_controller._send_command(
  File "/usr/local/lib/python3.11/site-packages/aioWiserHeatAPI/rest_controller.py", line 208, in _send_command
    return await self._do_hub_action(method, url, command_data)
  File "/usr/local/lib/python3.11/site-packages/aioWiserHeatAPI/rest_controller.py", line 112, in _do_hub_action
    await getattr(self._session, action.value)(
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 560, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 899, in start
    message, payload = await protocol.read()  # type: ignore[union-attr]
  File "/usr/local/lib/python3.11/site-packages/aiohttp/streams.py", line 616, in read
    await self._waiter
aiohttp.client_exceptions.ClientOSError: [Errno 104] Connection reset by peer
Verbindungsproblem zwischen HA und deinem Rolladencontroller? Der läuft über ne web api?
Was passiert wenn du alle gleichzeitig über normalen cover befehl runterfährst?
Richtig. Nicht direkt ne Web API. Die API könnte ich mir mit einem Befehl selber aus dem Hub ziehen. Neu einbinden habe ich ebenfalls versucht. Leider ohne Verbesserung.
Ich habe bei den Helfern eine Cover Gruppe des OG erstellt. Da immer noch das selbe Problem.
Ich könnte mir vorstellen das der sich beim Versuch alle Befehle gleichzeitig abzusenden verhaspelt. Oder der webserver der api das nicht mag.
