Nein, alle Geräte funktionieren!
Nur die Integration:
kann nicht geladen/registriert werden.
Hier noch eine beispielhafte Fehlermeldung:
Logger: homeassistant.config_entries
Quelle: config_entries.py:586
Erstmals aufgetreten: 08:16:12 (5 Vorkommnisse)
Zuletzt protokolliert: 08:16:12
Error setting up entry InternetGatewayDeviceV2 - Fritzbox-6660 for upnp
Error setting up entry InternetGatewayDeviceV2 - Fritzbox-7590 for upnp
Error setting up entry Fritzbox-7490 for upnp
Error setting up entry InternetGatewayDeviceV2 - Bollwerk for upnp
Error setting up entry InternetGatewayDeviceV2 - FRITZ!Box 6890 LTE for upnp
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 586, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/upnp/__init__.py", line 153, in async_setup_entry
device_entry = dev_registry.async_update_device(
File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 990, in async_update_device
new_values["identifiers"] = self._validate_identifiers(
File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 1091, in _validate_identifiers
raise DeviceIdentifierCollisionError(identifiers, existing_device)
homeassistant.helpers.device_registry.DeviceIdentifierCollisionError: Identifiers {('upnp', 'uuid:75802409-bccb-40e7-9f6c-2C91AB25A3E5::urn:schemas-upnp-org:device:InternetGatewayDevice:2'), ('upnp_host', '192.168.178.5')} already registered with DeviceEntry(area_id='buro', config_entries={'59c37e2150502f63dbae59acfeae29a3', 'debf392d866e698f3c09b2d032e4723b'}, configuration_url='http://192.168.178.5', connections={('upnp', 'uuid:75802409-bccb-40e7-9f6c-2C91AB25A3E5')}, disabled_by=None, entry_type=None, hw_version=None, id='2ddaafaa055df6a80c54676f74d6ff25', identifiers={('upnp', 'uuid:75802409-bccb-40e7-8e6c-2C91AB25A3E5::urn:schemas-upnp-org:device:InternetGatewayDevice:1'), ('upnp_host', '192.168.178.5')}, labels=set(), manufacturer='AVM Berlin', model='FRITZ!Box 6660 Cable', name_by_user=None, name='InternetGatewayDeviceV2 - Fritzbox-6660', primary_config_entry=None, serial_number=None, suggested_area=None, sw_version=None, via_device_id=None, is_new=False)
Nachtrag:
Habe jetzt mal die “gestörten” UPnP-Einträge gelöscht, da es sich um doppelte handeln, d.h. die gleichen Entitäten waren nochmals ungestört vorhanden.
Mal abwarten!
DWD habe ich mir die Arbeit gespart und einfach die Entitäten wieder so benannt, wie sie vor dem Update waren.
