Problem mit noah-mqtt
ich versuche mich an der Einbindung von noah-mqtt.
Habe es als Add-On installiert. Nun bekomme ich aber nach dem Start folgenden Fehler: (Seriennummer ausge-x-t)
{"time":"2025-01-24T10:36:16.6674425+01:00","level":"DEBUG","msg":"parameter data received","data":"{\"charging_limit\":100,\"discharge_limit\":30,\"output_power_w\":150}","device":"XXXXXXXX"}
{"time":"2025-01-24T10:36:16.682799629+01:00","level":"DEBUG","msg":"battery data received","BAT0":"{\"serial\":\"XXXXXXXX\",\"soc\":35,\"temp\":11}","BAT1":"{\"serial\":\"XXXXXXXXX\",\"soc\":39,\"temp\":10}","device":"XXXXXXXX"}
panic: EOF
goroutine 73 [running]:
noah-mqtt/internal/misc.Panic({0x3c28c0, 0x5ab9a0})
	/home/runner/work/noah-mqtt/noah-mqtt/internal/misc/panic.go:11 +0x98
main.connectMqtt.func2({0x0?, 0x0?}, {0x3c28c0, 0x5ab9a0})
	/home/runner/work/noah-mqtt/noah-mqtt/cmd/noah-mqtt/main.go:77 +0xc8
created by github.com/eclipse/paho%2emqtt%2egolang.(*client).internalConnLost.func1 in goroutine 71
	/home/runner/go/pkg/mod/github.com/eclipse/paho.mqtt.golang@v1.5.0/client.go:565 +0x3d0
Hat jemand ne Idee, was das Problem sein könnte?
Beste Grüße
