Plötzlich funktioniert meine Zigbee Integration nicht mehr
Wie komme ich einer nicht mehr funktionierenden Zigbee Integration auf die Schliche?
Da steht zwar ‘überprüfe die Protokolle’ … die ich zwar lesen, aber nicht deuten kann.
Kann jemand helfen?
[22:52:59] INFO: e[32mStarting mDNS Responder...e[0m
Default: mDNSResponder (Engineering Build) (Apr  3 2024 12:19:10) starting
cont-init: info: /etc/cont-init.d/check-cpcd-shm.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
e[34m-----------------------------------------------------------e[0m
e[34m Add-on: Silicon Labs Multiprotocole[0m
e[34m Zigbee and OpenThread multiprotocol add-one[0m
e[34m Add-on version: 2.4.5e[0m
e[32m You are running the latest version of this add-on.e[0m
e[34m System: Home Assistant OS 12.4  (amd64 / generic-x86-64)e[0m
e[34m Home Assistant Core: 2024.7.1e[0m
e[34m Home Assistant Supervisor: 2024.06.2e[0m
e[34m Please, share the above information when looking for helpe[0m
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[22:53:00] INFO: e[32mChecking /dev/ttyUSB0 identifying SkyConnect v1.0 from Nabu Casa.e[0m
[22:53:00] INFO: e[32mStarting universal-silabs-flasher with /dev/ttyUSB0e[0m
2024-07-10 22:53:00.572 homeassistant universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.3.1', ezsp_version='7.3.1.0', ot_rcp_version='SL-OPENTHREAD/2.3.1.0_GitHub-e6df00dd6' (2.3.1.0), cpc_version='4.3.1-4f7f9e99-dirty-de58d93e' (4.3.1), fw_type=<FirmwareImageType.RCP_UART_802154: 'rcp-uart-802154'>, baudrate=460800)
2024-07-10 22:53:00.573 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-07-10 22:53:02.581 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 460800 baud
2024-07-10 22:53:06.896 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 115200 baud
2024-07-10 22:53:11.212 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 230400 baud
2024-07-10 22:53:15.528 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.EZSP at 115200 baud
2024-07-10 22:53:20.540 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
Error: Failed to probe running application type
s6-rc: warning: unable to start service universal-silabs-flasher: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service mdns: stopping
s6-rc: info: service banner: stopping
Default: mDNSResponder (Engineering Build) (Apr  3 2024 12:19:10) stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[22:53:24] INFO: e[32mmDNS ended with exit code 4 (signal 0)...e[0m
s6-rc: info: service mdns successfully stopped
[22:57:48] INFO: e[32mThe otbr-web is disabled.e[0m
s6-rc: info: service mdns: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/check-cpcd-shm.sh
[22:57:48] INFO: e[32mStarting mDNS Responder...e[0m
[22:57:49] INFO: e[32mChecking /dev/ttyUSB0 identifying SkyConnect v1.0 from Nabu Casa.e[0m
[22:57:49] INFO: e[32mStarting universal-silabs-flasher with /dev/ttyUSB0e[0m
2024-07-10 22:57:50.129 homeassistant universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.3.1', ezsp_version='7.3.1.0', ot_rcp_version='SL-OPENTHREAD/2.3.1.0_GitHub-e6df00dd6' (2.3.1.0), cpc_version='4.3.1-4f7f9e99-dirty-de58d93e' (4.3.1), fw_type=<FirmwareImageType.RCP_UART_802154: 'rcp-uart-802154'>, baudrate=460800)
2024-07-10 22:57:50.129 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-07-10 22:57:52.137 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 460800 baud
2024-07-10 22:57:56.452 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 115200 baud
2024-07-10 22:58:00.769 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 230400 baud
2024-07-10 22:58:05.085 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.EZSP at 115200 baud
2024-07-10 22:58:10.096 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
[22:58:14] INFO: e[32mmDNS ended with exit code 4 (signal 0)...e[0m
Keine direkte Hilfe, da ich ZHA und auch den SkyConnect, nicht nutze, aber vielleicht Denkanstöße.
  1. wenn ich Multiprotokoll lese, dann habe ich hier im Forum schon öfter gelesen, dass man das nicht nutzen sollte.
    Suchergebnisse für „Multiprotokoll“ - simon42 Community
  2. ich lese im Log etwas von einer ezsp_version='7.3.1.. Ich glaube, da gibt es schon eine neuere.
  3. Wie sieht die Konfiguration von ZHA aus, das geht aktuell aus Deiner Problembeschreibung nicht hervor!
  4. was hast Du schon alles gemacht?
    • HA, vielleicht mehrmals gestoppt/gestartet?
    • die gesamte Hardware mal aus-, eingeschaltet?
    • SkyConnect mal abgezogen und nach einiger Zeit wieder angesteckt?
    • anderen USB-Port versucht?
  5. auch die anderen Rahmenbedingungen nennen,
    • wie und worauf läuft HA
  6. Plötzlich, kann nicht sein, was hast Du als letztes gemacht?
    • Updatest?
    • Konfiguration geändert?
  7. hier im Forum schon mal gesucht?
So, leider keine Lösung, hoffe trotzdem, dass Du schnell eine Lösung für Dein Problemfindest.
Danke für die vielen Ratschläge.
Ich denke, dass es am Multiprotokoll liegt, was zwar bisher funktionierte, aber nicht sehr zuverlässig in Bezug auf Updates und Änderungen zu sein scheint.
Ich werde ZHA und Matter/Thread von einander trennen.
Ich überlege, mir einen Aqara U3 Hub zu kaufen. Der vereint ja alles und sollte sich doch in HA einbinden lassen?
… oder lieber den Skyconnect behalten und zusätzlich einen ZHA Stick von SonOff besorgen?
Irgendwie geht mir das mit den Stick’s auf den Keks… alt. doch den HUB. Da muss ich mich wenigstens nicht mit mehreren Integrationen plagen.
Oder wie seht ihr das?
Bei den Themen bin ich raus, anstelle von ZHA setze ich auf Z2M, das dann auch nicht als Add-on, sondern unter Proxmox als LX Container und emqx MQTT Broker auch als LX Container.
Zu Matter/Thread habe ich keine Meinung, da fehlt mir einfach die Erfahrung und auch die Geräte, Zigbee klappt bei mir wunderbar, mit dem Entwicklerboard von Texas Instrument, das ich schon vor Jahren gekauft habe und immer noch zufrieden bin.
Wenn ich mir heute noch einmal ein Zigbee Gateway holen müsste, dann gleich eins, das per LAN/WLAN angebunden wird, siehe Zigbee2MQTT
Hybrid (USB + Network)
Gio-dot Z-Bee Duo with CC2652P
ZigStar LAN Coordinator
ZigStar PoE Coordinator
SMLIGHT SLZB-06 Zigbee+Matter/Thread+Bluetooth Ethernet USB POE WiFi LAN adapter
ZigStar UZG-01 - Universal ZigBee Gateway
SMLIGHT SLZB-06p7 Zigbee Ethernet USB POE WiFi LAN adapter
cod.m Zigbee Coordinator CC2652P7 (CZC-1.0)
Es ist gut möglich, dass für ZHA andere Koordinatoren besser geeignet sind, siehe Blakadder
