Hier der flow:
[{"id":"b44e5929af086b6f","type":"tab","label":"Test","disabled":false,"info":"","env":[]},{"id":"ab625dbbb21aef9d","type":"mqtt out","z":"b44e5929af086b6f","name":"WR MQTT","topic":"ahoy/ctrl/limit/0","qos":"2","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"87b2d138566ff5cc","x":1290,"y":160,"wires":[]},{"id":"ca660ffaa90da772","type":"function","z":"b44e5929af086b6f","name":"Berechnung für WR Limit","func":"// MAX generation of the inverter Watts\nvar maxPower = 800;\n\n// Get current power limit or default\nvar power = context.get('power') || maxPower;\npower += msg.payload;\n\n// clamp power between 0 and max\nif (power > maxPower) power = maxPower;\nif (power < 10) power = 100;\n\n\n// store current powerlimit and update message\ncontext.set('power', power);\nmsg.payload = power;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":240,"wires":[["8207edf9d601ec9c","bb018a8cce37f807"]]},{"id":"16100a47464cb6e0","type":"rbe","z":"b44e5929af086b6f","name":"entprellen","func":"deadband","gap":"2","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":300,"y":200,"wires":[["ca660ffaa90da772","b77ad86bc376d125"]]},{"id":"48451fd06f370ee5","type":"debug","z":"b44e5929af086b6f","name":"Check Ausgang","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1260,"y":340,"wires":[]},{"id":"fe100fc070f0da9c","type":"function","z":"b44e5929af086b6f","name":"zwischen 5% bis 100% (+0%)","func":"let eingangswert = msg.payload; // Eingangswert aus der msg.payload extrahieren\nlet mindestwert = 5;\n\nif (eingangswert < mindestwert) {\n eingangswert = mindestwert;\n} else if (eingangswert > 100) {\n eingangswert = 100;\n}\n\nif (eingangswert < 100) {\n eingangswert += 0;\n}\n\n// Hier kann der bereinigte Wert weiterverwendet werden\nmsg.payload = eingangswert;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1050,"y":240,"wires":[["ab625dbbb21aef9d","48451fd06f370ee5"]]},{"id":"a0fdf2e80aec3066","type":"rbe","z":"b44e5929af086b6f","name":"entprellen","func":"deadband","gap":"0","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1040,"y":340,"wires":[[]]},{"id":"bb018a8cce37f807","type":"range","z":"b44e5929af086b6f","minin":"1","maxin":"800","minout":"1","maxout":"100","action":"scale","round":true,"property":"payload","name":"Umrechnen in %","x":790,"y":240,"wires":[["fe100fc070f0da9c"]]},{"id":"8207edf9d601ec9c","type":"debug","z":"b44e5929af086b6f","name":"Check 2","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":640,"y":140,"wires":[]},{"id":"de62d4ed573c6e61","type":"server-state-changed","z":"b44e5929af086b6f","name":"Verbrauch > 0","server":"545f9309.a49cdc","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.total_power_3","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"0","halt_if_type":"num","halt_if_compare":"gt","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":240,"wires":[["16100a47464cb6e0"],["35442c2604c86bd3"]]},{"id":"35442c2604c86bd3","type":"rbe","z":"b44e5929af086b6f","name":"entprellen","func":"deadband","gap":"5","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":300,"y":280,"wires":[["ca660ffaa90da772","161ad9056bddf96c"]]},{"id":"161ad9056bddf96c","type":"debug","z":"b44e5929af086b6f","name":"Check 1","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":400,"y":360,"wires":[]},{"id":"b77ad86bc376d125","type":"debug","z":"b44e5929af086b6f","name":"Check 3","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":460,"y":140,"wires":[]},{"id":"a1924a07253cce02","type":"server-state-changed","z":"b44e5929af086b6f","name":"Akku voll?","server":"545f9309.a49cdc","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.solarflow_electric_level_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"100","halt_if_type":"num","halt_if_compare":"is_not","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":1060,"y":140,"wires":[[],[]]},{"id":"87b2d138566ff5cc","type":"mqtt-broker","name":"","broker":"192.168.178.35","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"545f9309.a49cdc","type":"server","name":"Home Assistant","addon":true}]
Danke
