Misux
3. Dezember 2024 um 19:58
1
HI!
Ich bekomme eine Menge Errormeldungen in meinem Zigbee2Mqtt…
Hat jemand eine Ahnung/Idee was man da machen sollte/könnte?
2024-12-03 20:54:44zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:54:44zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:54:48zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:54:48zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:54:55zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:54:55zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:55:36zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:55:36zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:55:46zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:55:46zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:55:47zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:55:47zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:55:48zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:55:48zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:55:51zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:55:51zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
2024-12-03 20:55:54zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
2024-12-03 20:55:54zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
totow
3. Dezember 2024 um 20:15
2
Auf die schnelle finde ich das:
opened 12:34PM - 04 May 24 UTC
problem
ezsp
### What happened?
After updating zigbee2mqtt to version 1.37.0 in HA I fond re… peated frame parsing error in the log:
`[2024-05-04 11:50:24] error: zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError: Attempt to access memory outside buffer bounds
at new NodeError (node:internal/errors:405:5)
at boundsError (node:internal/buffer:86:11)
at Buffer.readUInt16LE (node:internal/buffer:245:5)
at Buffer.readUIntLE (node:internal/buffer:182:17)
at Function.deserialize (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/types/basic.ts:19:67)
at new EZSPFrameData (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:180:54)
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:154:23
at Array.every (<anonymous>)
at Function.createFrame (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:148:15)
at Ezsp.onFrameReceived (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:439:35)
[2024-05-04 11:50:24] error: zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
The error repeats itself sporadically (6 times in 24h).
### What did you expect to happen?
_No response_
### How to reproduce it (minimal and precise)
I don't know any way to provoke the error.
### Zigbee2MQTT version
1.37.0 commit: unknown
### Adapter firmware version
EZSP v8 6.10.3.0 build 297
### Adapter
ZB-GW04
### Setup
Add-on on Homeassistant on Debian, VM x86-64, VMware
### Debug log
_No response_
Übrigens kann es nie schaden ein paar Infos hier zu lassen.
Version, Coordinator, Configuration, (Logs), …
Du musst immer bedenken wir kennen dein System nicht.
Tobi
Misux
4. Dezember 2024 um 06:40
3
Ach ja… Sorry…
Ich habe den Aeotec Zi-Stick https://aeotec.com/aeotec-z-stick-zigbee/
Leider spricht man dort von anderen Sticks. Habe soeben dort mal angefragt ob man das Furmwareupdate auch auf meinem Stick machen kann…
Welche Firmware ich habe weiß ich ehrlich gesagt nicht wo ich das im HA sehen kann…
Habs gefunden.
Das ist dann mein Stick und die Daten:
Weiß lemand ob man den irgendwie updaten kann?
Was wirklich komisch ist: Mein Kumpel hat exakt den gleiche Stick auch im HA und er hat solche Probleme nicht…
73ymw
5. Januar 2025 um 16:27
4
Misux
5. Januar 2025 um 17:07
5
Nein, habe mich nicht getraut weil ich 1. keinen ersatzstick habe falls es schief geht und 2 nicht wirklich besonders zufrieden bin mir seiner Leistung in meinem Haus… Ist aber eher das Haus schuld und die Position des Sticks (Im Keller)
73ymw
5. Januar 2025 um 17:08
6
Dann würde ich an deiner Stelle auf den Wechsel von Pi4 zu Pi5 verzichten. Es wird wahrscheinlich eher ein Stick-Problem sein.
Misux
5. Januar 2025 um 17:17
7
Die PI Umstellung mache ich unter anderem weil mein PI4 mit 2GB fast immer auf 80% Ram auslastung fährt… Und wer weiß was ich noch so machen möchte… Und er ist aaaalt
