IOS mit HA verbinden
ich möchte mein IPad mit HA verbinden, bei der Verbindung zwischen HA App und Ha kommt bei meinem Ipad folgende Fehler Meldung
Log 1: HA:
`2025-02-10 19:00:45.375 [Info] > Home Assistant Version: 2025.1 Build: 2025.1073 PID: 1457
2025-02-10 19:00:45.375 [Info] > XCGLogger Version: 7.0.1 - Level: Debug
2025-02-10 19:00:45.376 [Info] > XCGLogger writing log to: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/Home%20Assistant.txt
2025-02-10 19:00:45.386 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > webhook-io.robbie.HomeAssistant initial tasks: []
2025-02-10 19:00:45.386 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > non-background initial tasks: []
2025-02-10 19:00:45.388 [Info] [main] [ServerManager.swift:395] migrateIfNeeded() > no historic server found to import
2025-02-10 19:00:45.399 [Info] [main] [NotificationManagerLocalPushInterfaceExtension.swift:78] updateManagers() >
2025-02-10 19:00:45.409 [Verbose] [main] [NotificationManager.swift:56] setupFirebase() > Calling UIApplication.shared.registerForRemoteNotifications()
2025-02-10 19:00:45.422 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:00:46.321 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:00:46.321 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:00:46.322 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:00:46.322 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:00:46.323 [Verbose] [main] [ClientEventStore.swift:7] ClientEventStore > Adding client event: ClientEvent(id: "78481293-8538-41DA-B13B-81F15034BA08", text: "Application Starting", type: Shared.ClientEvent.EventType.unknown, jsonPayload: [:], date: 2025-02-10 18:00:46 +0000)
2025-02-10 19:00:46.332 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:00:46.332 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:00:46.332 [Info] [main] [ZoneManager.swift:87] log(state:) > initialize
2025-02-10 19:00:46.332 [Info] [main] [ZoneManager.swift:64] updateLocationManager(isInitial:) > started monitoring siglog changes
2025-02-10 19:00:46.340 [Info] [main] [ZoneManager.swift:194] sync(zones:) > available 0, enabled true, monitoring 0 ((beacon: 0, circular: 0, zone: 0)), started 0, ended 0
2025-02-10 19:00:46.345 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:00:46.345 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:00:46.356 [Info] [main] [WebViewWindowController.swift:64] setup() > showing onboarding required(HomeAssistant.OnboardingNavigationViewController.OnboardingStyle.RequiredType.full)
2025-02-10 19:00:46.376 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:00:46.376 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:00:46.386 [Info] [com.apple.root.user-initiated-qos] [RealmScene.swift:71] willDelete(objects:server:realm:) > deleting actions []
2025-02-10 19:00:46.461 [Verbose] [main] [NotificationManagerLocalPushInterfaceExtension.swift:141] configure(managers:) > computed managers: [:]
2025-02-10 19:00:46.461 [Verbose] [main] [NotificationManager.swift:69] didRegisterForRemoteNotifications(deviceToken:) > Successfully registered for push notifications! APNS token: ee551e10bd0ae819a5df8219f559ebd1d9d48d0cd879b8ad44b3be7da77270e1
2025-02-10 19:00:46.469 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason cold
2025-02-10 19:00:46.473 [Error] [main] [AppDelegate.swift:318] checkForAlerts() > check error: The first or last element was requested for an empty sequence
2025-02-10 19:00:48.466 [Info] [main] [Bonjour.swift:25] start() >
2025-02-10 19:00:48.949 [Info] [main] [NotificationManager.swift:334] messaging(_:didReceiveRegistrationToken:) > Firebase registration token refreshed, new token: d5ckaJs8UE6bkbFY7LID1x:APA91bFEwj9exLAkPnNDb638vAYcbcWe1CngONSeXkK7U75A0F0o177Gl8dF5YFdodcjficqeP1tMhhHr0MPXZ1evfkMxOa9-6q5W9kz8qKquJUYeSnKewE
2025-02-10 19:00:48.949 [Warning] [main] [NotificationManager.swift:337] messaging(_:didReceiveRegistrationToken:) > FCM token has changed from (null) to d5ckaJs8UE6bkbFY7LID1x:APA91bFEwj9exLAkPnNDb638vAYcbcWe1CngONSeXkK7U75A0F0o177Gl8dF5YFdodcjficqeP1tMhhHr0MPXZ1evfkMxOa9-6q5W9kz8qKquJUYeSnKewE
2025-02-10 19:00:59.752 [Info] [main] [Bonjour.swift:34] stop() >
2025-02-10 19:01:01.935 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:01:01.935 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:01:16.451 [Verbose] [main] [OnboardingManualURLViewController.swift:186] connect() > Onboard URL is http://192.168.178.210:8123
2025-02-10 19:01:16.451 [Verbose] [main] [OnboardingManualURLViewController.swift:189] connect() > Onboard URL after cleanup is http://192.168.178.210:8123
2025-02-10 19:01:16.454 [Info] [main] [OnboardingAuth.swift:85] performPreSteps(checkPoint:authDetails:sender:) > beforeAuth
2025-02-10 19:01:16.455 [Verbose] [main] [OnboardingAuthStepConnectivity.swift:25] perform(point:) >
2025-02-10 19:01:16.467 [Info] [main] [OnboardingAuth.swift:75] perform(checkPoint:checks:) > OnboardingAuthStepConnectivity: rejected(HomeAssistant.OnboardingAuthError(kind: HomeAssistant.OnboardingAuthError.ErrorKind.other(Error Domain=NSURLErrorDomain Code=-1009 "Es besteht anscheinend keine Verbindung zum Internet." UserInfo={_kCFStreamErrorCodeKey=50, NSUnderlyingError=0x303fa0d20 {Error Domain=kCFErrorDomainCFNetwork Code=-1009 "(null)" UserInfo={_NSURLErrorNWPathKey=unsatisfied (Local network prohibited), interface: en0[802.11], ipv4, uses wifi, _kCFStreamErrorCodeKey=50, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <980E1D2D-9DDA-44C3-B743-4B993F9C7EC6>.<1>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
    "LocalDataTask <980E1D2D-9DDA-44C3-B743-4B993F9C7EC6>.<1>"
), NSLocalizedDescription=Es besteht anscheinend keine Verbindung zum Internet., NSErrorFailingURLStringKey=http://192.168.178.210:8123/auth/authorize?response_type=code&client_id=https://home-assistant.io/iOS&redirect_uri=homeassistant://auth-callback, NSErrorFailingURLKey=http://192.168.178.210:8123/auth/authorize?response_type=code&client_id=https://home-assistant.io/iOS&redirect_uri=homeassistant://auth-callback, _kCFStreamErrorDomainKey=1}), data: nil))
2025-02-10 19:01:16.522 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:01:16.523 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.01.16+0100.logs.zip
2025-02-10 19:01:16.525 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:01:16.525 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:01:17.035 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:01:17.035 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.01.17+0100.logs.zip
2025-02-10 19:01:17.047 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:01:17.047 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:03:30.606 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:03:30.606 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.03.30+0100.logs.zip
2025-02-10 19:03:30.612 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:03:30.612 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:03:31.127 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:03:31.127 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.03.31+0100.logs.zip
2025-02-10 19:03:31.138 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:03:31.138 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:03:57.194 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:03:57.194 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:03:57.215 [Info] [com.apple.root.user-initiated-qos] [RealmScene.swift:71] willDelete(objects:server:realm:) > deleting actions []
2025-02-10 19:03:57.320 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason warm
2025-02-10 19:03:58.303 [Verbose] [main] [OnboardingManualURLViewController.swift:144] connectTapped(_:) > Connect button tapped
2025-02-10 19:03:59.809 [Verbose] [main] [OnboardingManualURLViewController.swift:186] connect() > Onboard URL is http://192.168.178.210:8123
2025-02-10 19:03:59.809 [Verbose] [main] [OnboardingManualURLViewController.swift:189] connect() > Onboard URL after cleanup is http://192.168.178.210:8123
2025-02-10 19:03:59.810 [Info] [main] [OnboardingAuth.swift:85] performPreSteps(checkPoint:authDetails:sender:) > beforeAuth
2025-02-10 19:03:59.810 [Verbose] [main] [OnboardingAuthStepConnectivity.swift:25] perform(point:) >
2025-02-10 19:03:59.815 [Info] [main] [OnboardingAuth.swift:75] perform(checkPoint:checks:) > OnboardingAuthStepConnectivity: rejected(HomeAssistant.OnboardingAuthError(kind: HomeAssistant.OnboardingAuthError.ErrorKind.other(Error Domain=NSURLErrorDomain Code=-1009 "Es besteht anscheinend keine Verbindung zum Internet." UserInfo={_kCFStreamErrorCodeKey=50, NSUnderlyingError=0x303f4d950 {Error Domain=kCFErrorDomainCFNetwork Code=-1009 "(null)" UserInfo={_NSURLErrorNWPathKey=unsatisfied (Local network prohibited), interface: en0[802.11], ipv4, uses wifi, _kCFStreamErrorCodeKey=50, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <B9D8107E-239E-4ABB-88FA-89186852E015>.<1>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
    "LocalDataTask <B9D8107E-239E-4ABB-88FA-89186852E015>.<1>"
2025-02-10 19:03:59.860 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:03:59.860 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.03.59+0100.logs.zip
2025-02-10 19:03:59.866 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:03:59.866 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:00.371 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:00.372 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.00+0100.logs.zip
2025-02-10 19:04:00.382 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:04:00.383 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:01.671 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:01.672 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.01+0100.logs.zip
2025-02-10 19:04:01.678 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:04:01.678 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:03.009 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:03.009 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.011 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:04:03.011 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:03.067 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:03.067 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.068 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.081 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:03.081 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.081 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.117 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:03.117 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.118 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.150 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:03.151 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.151 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.160 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:03.160 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:03.160 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.03+0100.logs.zip
2025-02-10 19:04:18.044 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:04:18.044 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:18.055 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason warm
2025-02-10 19:04:18.075 [Info] [com.apple.root.user-initiated-qos] [RealmScene.swift:71] willDelete(objects:server:realm:) > deleting actions []
2025-02-10 19:04:18.705 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:18.706 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.18+0100.logs.zip
2025-02-10 19:04:18.709 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:04:18.709 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:21.202 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:21.202 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.21+0100.logs.zip
2025-02-10 19:04:21.208 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:04:21.208 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:21.957 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:21.957 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.21+0100.logs.zip
2025-02-10 19:04:21.957 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.21+0100.logs.zip
2025-02-10 19:04:22.012 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:22.013 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.015 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:04:22.015 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:04:22.034 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:22.035 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.035 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.105 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:22.105 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.105 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.142 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:22.142 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.143 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.154 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:04:22.155 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:04:22.155 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.04.22+0100.logs.zip
2025-02-10 19:16:42.610 [Info] > Home Assistant Version: 2025.1 Build: 2025.1073 PID: 1522
2025-02-10 19:16:42.610 [Info] > XCGLogger Version: 7.0.1 - Level: Debug
2025-02-10 19:16:42.611 [Info] > XCGLogger appending log to: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/Home%20Assistant.txt
2025-02-10 19:16:42.620 [Info] [main] [ServerManager.swift:395] migrateIfNeeded() > no historic server found to import
2025-02-10 19:16:42.625 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > webhook-io.robbie.HomeAssistant initial tasks: []
2025-02-10 19:16:42.625 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > non-background initial tasks: []
2025-02-10 19:16:42.632 [Info] [main] [NotificationManagerLocalPushInterfaceExtension.swift:78] updateManagers() >
2025-02-10 19:16:42.641 [Verbose] [main] [NotificationManager.swift:56] setupFirebase() > Calling UIApplication.shared.registerForRemoteNotifications()
2025-02-10 19:16:42.647 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:16:42.647 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:16:43.722 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:16:43.722 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:16:43.725 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:16:43.725 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:16:43.726 [Verbose] [main] [ClientEventStore.swift:7] ClientEventStore > Adding client event: ClientEvent(id: "1657A4FD-C0C1-44EB-94D2-CAEFB7387520", text: "Application Starting", type: Shared.ClientEvent.EventType.unknown, jsonPayload: [:], date: 2025-02-10 18:16:43 +0000)
2025-02-10 19:16:43.739 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:16:43.739 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:16:43.741 [Info] [main] [ZoneManager.swift:87] log(state:) > initialize
2025-02-10 19:16:43.741 [Info] [main] [ZoneManager.swift:64] updateLocationManager(isInitial:) > started monitoring siglog changes
2025-02-10 19:16:43.752 [Info] [main] [ZoneManager.swift:194] sync(zones:) > available 0, enabled true, monitoring 0 ((beacon: 0, circular: 0, zone: 0)), started 0, ended 0
2025-02-10 19:16:43.758 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:16:43.758 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:16:43.768 [Info] [main] [WebViewWindowController.swift:64] setup() > showing onboarding required(HomeAssistant.OnboardingNavigationViewController.OnboardingStyle.RequiredType.full)
2025-02-10 19:16:43.787 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:16:43.787 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:16:43.796 [Info] [com.apple.root.user-initiated-qos] [RealmScene.swift:71] willDelete(objects:server:realm:) > deleting actions []
2025-02-10 19:16:43.842 [Verbose] [main] [NotificationManagerLocalPushInterfaceExtension.swift:141] configure(managers:) > computed managers: [:]
2025-02-10 19:16:43.842 [Verbose] [main] [NotificationManager.swift:69] didRegisterForRemoteNotifications(deviceToken:) > Successfully registered for push notifications! APNS token: ee551e10bd0ae819a5df8219f559ebd1d9d48d0cd879b8ad44b3be7da77270e1
2025-02-10 19:16:43.850 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason cold
2025-02-10 19:16:43.855 [Info] [main] [NotificationManager.swift:334] messaging(_:didReceiveRegistrationToken:) > Firebase registration token refreshed, new token: d5ckaJs8UE6bkbFY7LID1x:APA91bFEwj9exLAkPnNDb638vAYcbcWe1CngONSeXkK7U75A0F0o177Gl8dF5YFdodcjficqeP1tMhhHr0MPXZ1evfkMxOa9-6q5W9kz8qKquJUYeSnKewE
2025-02-10 19:16:43.874 [Error] [main] [AppDelegate.swift:318] checkForAlerts() > check error: The first or last element was requested for an empty sequence
2025-02-10 19:16:44.727 [Info] [main] [Bonjour.swift:25] start() >
2025-02-10 19:16:48.488 [Info] [main] [Bonjour.swift:34] stop() >
2025-02-10 19:16:49.989 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:16:49.989 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:17:03.726 [Verbose] [main] [OnboardingManualURLViewController.swift:186] connect() > Onboard URL is http://192.168.178.210:8123
2025-02-10 19:17:03.726 [Verbose] [main] [OnboardingManualURLViewController.swift:189] connect() > Onboard URL after cleanup is http://192.168.178.210:8123
2025-02-10 19:17:03.728 [Info] [main] [OnboardingAuth.swift:85] performPreSteps(checkPoint:authDetails:sender:) > beforeAuth
2025-02-10 19:17:03.728 [Verbose] [main] [OnboardingAuthStepConnectivity.swift:25] perform(point:) >
2025-02-10 19:17:03.738 [Info] [main] [OnboardingAuth.swift:75] perform(checkPoint:checks:) > OnboardingAuthStepConnectivity: rejected(HomeAssistant.OnboardingAuthError(kind: HomeAssistant.OnboardingAuthError.ErrorKind.other(Error Domain=NSURLErrorDomain Code=-1009 "Es besteht anscheinend keine Verbindung zum Internet." UserInfo={_kCFStreamErrorCodeKey=50, NSUnderlyingError=0x3000b0090 {Error Domain=kCFErrorDomainCFNetwork Code=-1009 "(null)" UserInfo={_NSURLErrorNWPathKey=unsatisfied (Local network prohibited), interface: en0[802.11], ipv4, uses wifi, _kCFStreamErrorCodeKey=50, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <07FBA15D-3D06-460F-AF6E-726A40167BD2>.<1>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
    "LocalDataTask <07FBA15D-3D06-460F-AF6E-726A40167BD2>.<1>"
2025-02-10 19:17:03.780 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:17:03.780 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.17.03+0100.logs.zip
2025-02-10 19:17:03.787 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:17:03.787 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:17:04.293 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:17:04.294 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.17.04+0100.logs.zip
2025-02-10 19:17:04.305 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:17:04.305 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:18:04.553 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:18:04.554 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.18.04+0100.logs.zip
2025-02-10 19:18:04.560 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:18:04.560 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:18:05.486 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:18:05.486 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.489 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:18:05.489 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:18:05.546 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:18:05.546 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.546 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.558 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:18:05.559 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.559 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.592 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:18:05.592 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.593 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.624 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:18:05.624 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.624 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.633 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:18:05.634 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:18:05.634 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.18.05+0100.logs.zip
2025-02-10 19:23:14.773 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:14.773 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:14.779 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason warm
2025-02-10 19:23:14.823 [Info] [com.apple.root.user-initiated-qos] [RealmScene.swift:71] willDelete(objects:server:realm:) > deleting actions []
2025-02-10 19:23:15.296 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:15.297 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.15+0100.logs.zip
2025-02-10 19:23:15.303 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:15.303 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:15.986 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:15.986 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.15+0100.logs.zip
2025-02-10 19:23:15.986 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.23.15+0100.logs.zip
2025-02-10 19:23:16.497 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:16.498 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.16+0100.logs.zip
2025-02-10 19:23:16.506 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:16.506 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:17.661 [Verbose] [main] [OnboardingManualURLViewController.swift:144] connectTapped(_:) > Connect button tapped
2025-02-10 19:23:18.966 [Verbose] [main] [OnboardingManualURLViewController.swift:186] connect() > Onboard URL is http://192.168.178.210:8123
2025-02-10 19:23:18.966 [Verbose] [main] [OnboardingManualURLViewController.swift:189] connect() > Onboard URL after cleanup is http://192.168.178.210:8123
2025-02-10 19:23:18.966 [Info] [main] [OnboardingAuth.swift:85] performPreSteps(checkPoint:authDetails:sender:) > beforeAuth
2025-02-10 19:23:18.966 [Verbose] [main] [OnboardingAuthStepConnectivity.swift:25] perform(point:) >
2025-02-10 19:23:18.971 [Info] [main] [OnboardingAuth.swift:75] perform(checkPoint:checks:) > OnboardingAuthStepConnectivity: rejected(HomeAssistant.OnboardingAuthError(kind: HomeAssistant.OnboardingAuthError.ErrorKind.other(Error Domain=NSURLErrorDomain Code=-1009 "Es besteht anscheinend keine Verbindung zum Internet." UserInfo={_kCFStreamErrorCodeKey=50, NSUnderlyingError=0x300071620 {Error Domain=kCFErrorDomainCFNetwork Code=-1009 "(null)" UserInfo={_NSURLErrorNWPathKey=unsatisfied (Local network prohibited), interface: en0[802.11], ipv4, uses wifi, _kCFStreamErrorCodeKey=50, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <C6844798-B820-4072-9652-54CA7C69CA16>.<1>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
    "LocalDataTask <C6844798-B820-4072-9652-54CA7C69CA16>.<1>"
2025-02-10 19:23:19.018 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:19.019 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.19+0100.logs.zip
2025-02-10 19:23:19.025 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:19.025 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:19.530 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:19.531 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.19+0100.logs.zip
2025-02-10 19:23:19.532 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.23.19+0100.logs.zip
2025-02-10 19:23:23.895 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:23.896 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.23+0100.logs.zip
2025-02-10 19:23:23.903 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:23.903 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:24.787 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:24.788 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.790 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:24.790 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:24.842 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:24.842 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.842 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.852 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:24.853 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.853 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.890 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:24.891 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.891 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.927 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:24.927 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.927 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.941 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:24.941 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:24.942 [Error] [main] [XCGLogger+Export.swift:66] archiveURL() > Failed to create archive at /private/var/mobile/Containers/Data/Application/E8B9F063-88A2-408C-8F34-EA377A63DC4C/tmp/2025-02-10_19.23.24+0100.logs.zip
2025-02-10 19:23:45.305 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:45.305 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:45.320 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason warm
2025-02-10 19:23:45.324 [Info] [com.apple.root.user-initiated-qos] [RealmScene.swift:71] willDelete(objects:server:realm:) > deleting actions []
2025-02-10 19:23:45.806 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:45.807 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.45+0100.logs.zip
2025-02-10 19:23:45.813 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:45.813 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:47.032 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:23:47.033 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.23.47+0100.logs.zip
2025-02-10 19:23:47.038 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:47.038 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:48.099 [Info] [main] [Environment.swift:56] init() > PromiseKit: warning: pending guarantee deallocated
2025-02-10 19:23:49.229 [Info] > Home Assistant Version: 2025.1 Build: 2025.1073 PID: 1528
2025-02-10 19:23:49.229 [Info] > XCGLogger Version: 7.0.1 - Level: Debug
2025-02-10 19:23:49.231 [Info] > XCGLogger appending log to: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/Home%20Assistant.txt
2025-02-10 19:23:49.233 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > webhook-io.robbie.HomeAssistant initial tasks: []
2025-02-10 19:23:49.233 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > non-background initial tasks: []
2025-02-10 19:23:49.233 [Info] [main] [ServerManager.swift:395] migrateIfNeeded() > no historic server found to import
2025-02-10 19:23:49.236 [Info] [main] [NotificationManagerLocalPushInterfaceExtension.swift:78] updateManagers() >
2025-02-10 19:23:49.242 [Verbose] [main] [NotificationManager.swift:56] setupFirebase() > Calling UIApplication.shared.registerForRemoteNotifications()
2025-02-10 19:23:49.244 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:49.244 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:49.285 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:49.285 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:49.286 [Verbose] [main] [ClientEventStore.swift:7] ClientEventStore > Adding client event: ClientEvent(id: "0EEB9081-9D98-47B4-B18B-7CCC7471B2B3", text: "Application Starting", type: Shared.ClientEvent.EventType.unknown, jsonPayload: [:], date: 2025-02-10 18:23:49 +0000)
2025-02-10 19:23:49.289 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:49.289 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:49.289 [Info] [main] [ZoneManager.swift:87] log(state:) > initialize
2025-02-10 19:23:49.289 [Info] [main] [ZoneManager.swift:64] updateLocationManager(isInitial:) > started monitoring siglog changes
2025-02-10 19:23:49.293 [Info] [main] [ZoneManager.swift:194] sync(zones:) > available 0, enabled true, monitoring 0 ((beacon: 0, circular: 0, zone: 0)), started 0, ended 0
2025-02-10 19:23:49.295 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:49.295 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:49.301 [Info] [main] [WebViewWindowController.swift:64] setup() > showing onboarding required(HomeAssistant.OnboardingNavigationViewController.OnboardingStyle.RequiredType.full)
2025-02-10 19:23:49.310 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:49.310 [Verbose] [com.apple.root.user-initiated-qos] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:23:49.319 [Info] [com.apple.root.user-initiated-qos] [RealmScene.swift:71] willDelete(objects:server:realm:) > deleting actions []
2025-02-10 19:23:49.337 [Verbose] [main] [NotificationManagerLocalPushInterfaceExtension.swift:141] configure(managers:) > computed managers: [:]
2025-02-10 19:23:49.337 [Verbose] [main] [NotificationManager.swift:69] didRegisterForRemoteNotifications(deviceToken:) > Successfully registered for push notifications! APNS token: ee551e10bd0ae819a5df8219f559ebd1d9d48d0cd879b8ad44b3be7da77270e1
2025-02-10 19:23:49.340 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason cold
2025-02-10 19:23:49.342 [Info] [main] [NotificationManager.swift:334] messaging(_:didReceiveRegistrationToken:) > Firebase registration token refreshed, new token: d5ckaJs8UE6bkbFY7LID1x:APA91bFEwj9exLAkPnNDb638vAYcbcWe1CngONSeXkK7U75A0F0o177Gl8dF5YFdodcjficqeP1tMhhHr0MPXZ1evfkMxOa9-6q5W9kz8qKquJUYeSnKewE
2025-02-10 19:23:49.442 [Error] [main] [AppDelegate.swift:318] checkForAlerts() > check error: The first or last element was requested for an empty sequence
2025-02-10 19:23:50.224 [Info] [main] [Bonjour.swift:25] start() >
2025-02-10 19:23:54.622 [Info] [main] [Bonjour.swift:34] stop() >
2025-02-10 19:23:55.893 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:23:55.894 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:24:18.723 [Verbose] [main] [OnboardingManualURLViewController.swift:144] connectTapped(_:) > Connect button tapped
2025-02-10 19:24:18.730 [Verbose] [main] [OnboardingManualURLViewController.swift:186] connect() > Onboard URL is http://192.168.178.210:8123
2025-02-10 19:24:18.730 [Verbose] [main] [OnboardingManualURLViewController.swift:189] connect() > Onboard URL after cleanup is http://192.168.178.210:8123
2025-02-10 19:24:18.731 [Info] [main] [OnboardingAuth.swift:85] performPreSteps(checkPoint:authDetails:sender:) > beforeAuth
2025-02-10 19:24:18.731 [Verbose] [main] [OnboardingAuthStepConnectivity.swift:25] perform(point:) >
2025-02-10 19:24:18.742 [Info] [main] [OnboardingAuth.swift:75] perform(checkPoint:checks:) > OnboardingAuthStepConnectivity: rejected(HomeAssistant.OnboardingAuthError(kind: HomeAssistant.OnboardingAuthError.ErrorKind.other(Error Domain=NSURLErrorDomain Code=-1009 "Es besteht anscheinend keine Verbindung zum Internet." UserInfo={_kCFStreamErrorCodeKey=50, NSUnderlyingError=0x303f39080 {Error Domain=kCFErrorDomainCFNetwork Code=-1009 "(null)" UserInfo={_NSURLErrorNWPathKey=unsatisfied (Local network prohibited), interface: en0[802.11], ipv4, uses wifi, _kCFStreamErrorCodeKey=50, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <AB3A888C-CBF9-4845-A5EF-C5483CFCEB16>.<1>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
    "LocalDataTask <AB3A888C-CBF9-4845-A5EF-C5483CFCEB16>.<1>"
2025-02-10 19:24:18.802 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:24:18.803 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.24.18+0100.logs.zip
2025-02-10 19:24:18.810 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:24:18.810 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2025-02-10 19:24:19.309 [Verbose] [main] [XCGLogger+Export.swift:49] archiveURL() > Logs directory is: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/
2025-02-10 19:24:19.309 [Debug] [main] [XCGLogger+Export.swift:62] archiveURL() > Exporting logs as filename 2025-02-10_19.24.19+0100.logs.zip
2025-02-10 19:24:19.319 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2025-02-10 19:24:19.319 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28`
Log 2: HomeAssistant-Extensions-Intents:
`2025-02-10 19:00:45.593 [Info] > HomeAssistant-Extensions-Intents Version: 2025.1 Build: 2025.1073 PID: 1459
2025-02-10 19:00:45.593 [Info] > XCGLogger Version: 7.0.1 - Level: Debug
2025-02-10 19:00:45.595 [Info] > XCGLogger writing log to: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/HomeAssistant-Extensions-Intents.txt
2025-02-10 19:00:45.596 [Info] [com.apple.siri.extension] [IntentHandlerFactory.swift:36] handler(for:) > for <AssistInAppIntent: 0x1060c9900> {
    server = <null>;
    pipeline = <null>;
    withVoice = <null>;
} found handler <Shared.AssistInAppIntentHandler: 0x1060f81b0>
2025-02-10 19:00:45.596 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > webhook-io.robbie.HomeAssistant.Intents initial tasks: []
2025-02-10 19:00:45.597 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > non-background initial tasks: []
2025-02-10 19:00:45.597 [Info] [com.apple.siri.extension] [IntentHandlerFactory.swift:36] handler(for:) > for <AssistInAppIntent: 0x1060c8b40> {
    server = <null>;
    pipeline = <null>;
    withVoice = <null>;
} found handler <Shared.AssistInAppIntentHandler: 0x1060f85b0>
2025-02-10 19:00:45.598 [Info] [com.apple.siri.extension] [ServerManager.swift:395] migrateIfNeeded() > no historic server found to import
2025-02-10 19:00:45.598 [Info] [com.apple.siri.extension] [IntentHandlerFactory.swift:36] handler(for:) > for <WidgetOpenPageIntent: 0x1060c90e0> {
    pages = <null>;
} found handler <Shared.OpenPageIntentHandler: 0x1060f8070>`
Log 3: HomeAssistant-Extensions-Widgets:
`2025-02-10 19:00:45.376 [Info] > HomeAssistant-Extensions-Widgets Version: 2025.1 Build: 2025.1073 PID: 1458
2025-02-10 19:00:45.376 [Info] > XCGLogger Version: 7.0.1 - Level: Debug
2025-02-10 19:00:45.377 [Info] > XCGLogger writing log to: file:///private/var/mobile/Containers/Shared/AppGroup/A89C8325-EDAC-45E9-9EBE-57B8EAF026AC/logs/HomeAssistant-Extensions-Widgets.txt
2025-02-10 19:00:45.386 [Info] [webhookmanager-data] [WebhookManager.swift:804] init(identifier:delegate:delegateQueue:background:) > webhook-io.robbie.HomeAssistant.Widgets initial tasks: []
2025-02-10 19:00:45.388 [Info] [main] [ServerManager.swift:395] migrateIfNeeded() > no historic server found to import`
kann mir da jemand weiter helfen was da nicht passt bei der Anmeldung auf dem HA.
:crayon:by HarryP: Log-/Codezeilen formatiert (bitte immer in </> einbinden)
So wie du das Log hier reinbringst, blickt das keiner.
Kannst du den Block bitte mit </> formatieren?
Hast du das, was im Screenshot geschrieben steht, bereits überprüft?
Wenn es das in der App von Home Assistant ist (Einstellungen–> Apps → HA), dann habe ich das aktiviert. Das Problem besteht nach wie vor.
Was hast du als HA-URL in der App eingestellt?
Ich habe http:// IP Adresse HA:8123 eingegeben.
Andere Geräte, z.B. Shellys, kannst du mit dem Browser erreichen?
Mit einem Browser kannst du eine Verbindung zu HA herstellen?
Hast du eventuell getrennte Netzwerke? Also LAN und WLAN mit anderen IP-Bereichen?
Wenn ich mit dem IPad über Safari den HA aufrufe erreiche ich ihn. Ich bin im selben Netzwerk wie der HA erreiche ich ihn nicht über die App. Die zwei Router wo ich habe sind zusammen auch im selben netzwerk.
Hm, App deinstallieren und noch mal installieren.
Etwas anderes fällt mir jetzt auch nicht ein.
Ich finde das auf meinem iPhone hier: Einstellungen > Datenschutz & Sicherheit > Lokales Netzwerk > Home Assistant
Ich habe jetzt folgenden Pfad genommen und die Lokales Netzwerk bei HA aktiviert, leider ohne Erfolg. Kann es sein, das in der yaml datei fehlt. Als ich damals das mit meine Android Handy verbinden wollt hat der befehl mobile_app gefehlt. Nach dem ich das eingetragen habe konnte ich mich mit meinem Handy verbinden. Muss da so etwas für IOS auch gemacht werden.
Eigentlich nicht. Wie sieht denn deine configuration.yaml aus?
Config yaml
Das wäre der Eintrag in der configuration.yaml bei mir, das ich die Mobile App auf meinem Handy öffnen kann.
Funktioniert bei mir auch ohne den Eintrag in der configuration.yaml.
2 Router? Wer hat denn 2 Router? Hast du die HomeAssistent Cloud aktiv? Irgendwelche Firewall Rules aktiv die das Apple Discovery Protokoll verhindern?
Im Browser gibst du IP ja manuell ein, die App versucht beim Start via Discovery dein HA zu finden oder mehrere wenn man mehrere Instanzen hat. Es scheitert da beim Finden.
Wie heissen denn die beiden Router?
