Hyper2000 Sensoren zu 0 setzen
Hallo
ich habe folgenden Code von Z-Master42 zur verfügung . Stehe aber auf dem Schlaf wo genau es rein muss mit welcher Einrückung
alias: SolarFlow Power-Sensoren nullen
description: >-
  Wenn sich der Wert eines Power-Sensors innerhalb der letzten drei Minuten
  nicht geändert hat, wird er auf 0 W gesetzt.
trigger:
  - platform: template
    value_template: >-
      {{ (as_timestamp(now()) -
      as_timestamp(states.sensor.solarflow_pack_input_power.last_changed)) > 180
    value_template: >-
      as_timestamp(states.sensor.solarflow_output_pack_power.last_changed)) > 180
    value_template: >-
      as_timestamp(states.sensor.solarflow_solar_input_power.last_changed))
      > 180 }}
    value_template: >-
      as_timestamp(states.sensor.solarflow_output_home_power.last_changed)) > 180
    value_template: >-
      as_timestamp(states.sensor.solarflow_solar_power_1.last_changed)) > 180 }}
    value_template: >-
      as_timestamp(states.sensor.solarflow_solar_power_2.last_changed)) > 180 }}
condition: []
action:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - packInputPower
          - condition: numeric_state
            entity_id: sensor.solarflow_pack_input_power
            above: 0
        sequence:
          - service: mqtt.publish
              qos: "0"
              topic: <appKey>/<deviceID>/state
              payload: "{\"packInputPower\":0}"
      - conditions:
            id:
              - outputPackPower
            entity_id: sensor.solarflow_output_pack_power
            above: 0
        sequence:
              qos: "0"
              payload: "{\"outputPackPower\":0}"
      - conditions:
            id:
              - solarInputPower
            entity_id: sensor.solarflow_solar_input_power
            above: 0
        sequence:
              qos: "0"
              payload: "{\"solarInputPower\":0}"
      - conditions:
            id:
              - outputHomePower
            entity_id: sensor.solarflow_output_home_power
            above: 0
        sequence:
              qos: "0"
              payload: "{\"outputHomePower\":0}"
      - conditions:
            id:
              - solarPower1
            entity_id: sensor.solarflow_solar_power_1
            above: 0
        sequence:
              qos: "0"
              payload: "{\"solarPower1\":0}"
      - conditions:
            id:
              - solarPower2
            entity_id: sensor.solarflow_solar_power_2
            above: 0
        sequence:
              qos: "0"
              payload: "{\"solarPower2\":0}"
mode: parallel
brauche da mal Hilfe bitte
