Honeywell Home TTC security
Hallo, habe ein Alarmsystem von Honeywell in Betrieb.
Leider ist die Integration in HA nicht möglich.
Gibt es hier eine andere Möglichkeit, lg?
Auszug Homeassistant:
The evohome integration links Home Assistant with all non-US Honeywell Total Connect Comfort (TCC) CH/DHW systems, such as:
  • the Honeywell Evohome CH/DHW system, and
  • the Honeywell Mobile Access Kit with a Round Thermostat
It does not support the home security functionality of TCC.
It uses the evohome-async client library.
For your system to be compatible with this integration, then you must be able to access it via https://international.mytotalconnectcomfort.com/ (note the ‘international’).
