Bin ich blind?
Oder hast du was vergessen
Hm - bei mir ist es halt nicht so. So sieht z.B. mein MQTT Broker Log der letzten Stunden aus
2025-01-15 03:13:33: New connection from 172.30.33.2:58648 on port 1883.
2025-01-15 03:13:33: New client connected from 172.30.33.2:58648 as Wolf_19216812 (p2, c1, k15, u'addons').
2025-01-15 03:32:24: Saving in-memory database to /data//mosquitto.db.
2025-01-15 04:02:25: Saving in-memory database to /data//mosquitto.db.
2025-01-15 04:32:26: Saving in-memory database to /data//mosquitto.db.
2025-01-15 05:02:27: Saving in-memory database to /data//mosquitto.db.
2025-01-15 05:32:28: Saving in-memory database to /data//mosquitto.db.
2025-01-15 06:02:29: Saving in-memory database to /data//mosquitto.db.
2025-01-15 06:32:30: Saving in-memory database to /data//mosquitto.db.
2025-01-15 07:02:31: Saving in-memory database to /data//mosquitto.db.
2025-01-15 07:32:32: Saving in-memory database to /data//mosquitto.db.
2025-01-15 08:02:33: Saving in-memory database to /data//mosquitto.db.
2025-01-15 08:32:34: Saving in-memory database to /data//mosquitto.db.
2025-01-15 09:02:35: Saving in-memory database to /data//mosquitto.db.
2025-01-15 09:32:36: Saving in-memory database to /data//mosquitto.db.
2025-01-15 10:02:37: Saving in-memory database to /data//mosquitto.db.
2025-01-15 10:32:38: Saving in-memory database to /data//mosquitto.db.
2025-01-15 11:02:39: Saving in-memory database to /data//mosquitto.db.
2025-01-15 11:32:40: Saving in-memory database to /data//mosquitto.db.
2025-01-15 11:49:53: Client 2HFjW7hm8rGaGaRjadpLJi closed its connection.
2025-01-15 11:50:05: New connection from 192.168.1.61:33237 on port 1883.
2025-01-15 11:50:05: New client connected from 192.168.1.61:33237 as 6T8Rhr1aZ8AQhgj30eGzT4rnM (p2, c1, k90, u'mqtt_user').
2025-01-15 12:02:41: Saving in-memory database to /data//mosquitto.db.
2025-01-15 12:32:42: Saving in-memory database to /data//mosquitto.db.
2025-01-15 13:02:43: Saving in-memory database to /data//mosquitto.db.
2025-01-15 13:32:44: Saving in-memory database to /data//mosquitto.db.
2025-01-15 14:02:45: Saving in-memory database to /data//mosquitto.db.
2025-01-15 14:32:46: Saving in-memory database to /data//mosquitto.db.
2025-01-15 15:02:47: Saving in-memory database to /data//mosquitto.db.
2025-01-15 15:32:48: Saving in-memory database to /data//mosquitto.db.
2025-01-15 16:02:49: Saving in-memory database to /data//mosquitto.db.
2025-01-15 16:32:50: Saving in-memory database to /data//mosquitto.db.
und wie man sehen kann gab es da lediglich einmal in der Nach um 3:13:33 die Abfrage des Supervisors über die IP 172.30.33.2
Ich kann mich noch schwach daran erinnern das ich so etwas bei mir auch schon mal gesehen hatte, aber das ist bestimmt schon zwei oder drei Jahre her.
Aktuell habe ich aber auch keine Idee warum das bei Euch angezeigt wird und bei mir nicht. Ich wüsste im Moment nicht wie ich den Supervisor irgendwie beeinflussen kann in welchen Abständen der den MQTT Broker abfragt und/oder auch nicht das Log des MQTT Broker wann da wer was und wie eintragen kann.
na bei @djeeens sieht es so aus wie bei uns.
Wahrscheinlich wenn mal ein paar mehr gucken sieht es bei denen auch so aus! Keine Ahnung aber es läuft und das ist ja die Hauptsache.
(man muss auch nicht immer alles verstehen was da so abläuft)
@Jim_OS
Du hast Mosquito auch als Addon in HomeAssistant laufen ? (Oder ausgelagert im LXC/VM ?)
Ne als Addon. Siehe Screenshot im Startposting.
Ergänzung: Bei mir läuft aber auch noch HA Core 2024.12.5. Wobei ich jetzt nicht glaube das das die Ursache dafür ist das mein Supervisor so “zurückhaltend” ist.
Okok … ja interessant … was ist bei dir anders als bei mir & @fazer1000 ?
Wie gesagt, bisher habe ich keine Probleme
Hmm, könnte es etwas mit der IP zutun habe?
Bei uns ist sie 172.30.32.2
mal kurz in google geschaut bei anderen läuft das auch so nen link aus 2021
→ github
Ja den Link kenne ich aber der ist eben auch aus 2021. Was ganz gut mit den von mir erwähnten 2 - 3 Jahr her zusammenpasst.
… das heißt bei uns ist es gut und bei @Jim_OS schlecht ??
… bin verwirrt
Bei Euch prüft der Supervisor halt alle 2 Minuten ob der MQTT Broker noch lebt und bei mir scheinbar nur alle paar Stunden. Aber wie schon gesagt habe ich im Moment keine Idee warum es diesen Unterschied gibt.
schlecht wird es erst wenn nicht mehr geht
so lange alles geht und funktioniert werde ich das ignorieren.
Ich sehe das jetzt auch nicht als wirkliches Problem an und wer weiß vielleicht ist es bei mir dann ja auch (wieder) so mit der 2-Minuten-Abfrage wenn ich das Update auf HA Core 2025.1.2 mache. Man wird sehen.
@Jim_OS hast du noch zusätzlich was bei dir in der configuration.yaml geschrieben zum mqtt
Gute Tipp bzw. gute Frage. Ich glaube jetzt kommen wir der Sache auf die Spur.
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
das werde ich gleich mal ausprobieren, jetzt fängt die spielerei an
Ich hatte das mal in meiner configuration.yaml stehen … aber irgendwie ist es da nicht mehr
@Jim_OS also das steht bei mir:
trusted_proxies:
- 172.30.33.0/24
am mqtt broker fragt die ip 172.30.32.2 ab.
So jetzt haben wir noch mehr fragen!
Hätte ich blos nicht geguckt
@Jim_OS vll weißt du es ja, wo sehe ich den überhaupt was von meinem HA Supervisor die IP ist.
Vll hatte ich die config… ja schon von Anfang an mit der falschen IP bestückt!
Ich benutzt HA jetzt seit 4 oder 5 Jahren durchgehend, sprich das ist immer noch die erste Version die ich mal eingerichtet hatte und ich habe an der configuration.yaml auch nur dann etwas verändert wenn es notwendig war. Ich kann nicht mehr sagen ob der trusted_proxies:
Eintrag da schon von Anfang an bei mir war, oder ob ich den z.B. erst irgendwann z.B. 2021 eingetragen habe weil mich vielleicht diese 2-Minuten-Abfragen gestört haben und/oder ich sie für überflüssig gehalten habe.
Ich kann auch nicht sagen warum bei mir der Supervisor eine IP aus dem 172.30.33.x Bereich benutzt und bei Euch eine aus dem IP-Bereich 172.30.32.x. Soweit ich weiß läuft der Supervisor-Teil von HA auch als Docker, aber ich habe keine Ahnung welche Docker dann welche IPs haben, bekommen, oder benutzen. Bei mir läuft HA in einer VM unter Proxmox. Vielleicht kommt daher ja der unterschiedliche IP-Bereich für den Supervisor. Keine Ahnung.
VG JIm
