### The problem
Every time there’s an internet interruption, my tibber integrat…ion stops working. All sensors remain stuck at their last recorded value. After restarting the integration, the values are retrieved again. My internet provider forces a disconnection at least once a day. On some days, I experience multiple interruptions.
I completely reinstalled Home Assistant with version 2026.4.1 (no data import) and have observed the same problem in 2026.4.2 and 2026.4.3.
Logger: tibber.home
Quelle: /usr/local/lib/python3.14/site-packages/tibber/home.py:460
Erstmals aufgetreten: 01:57:15 (1 Vorkommnis)
Zuletzt protokolliert: 01:57:15
Error in rt_subscribe
File "/usr/local/lib/python3.14/site-packages/tibber/home.py", line 443, in _start
async for _data in session.subscribe(
...<14 lines>...
return
File "/usr/local/lib/python3.14/site-packages/gql/client.py", line 1426, in subscribe
async for result in inner_generator:
...<13 lines>...
yield result.data
File "/usr/local/lib/python3.14/site-packages/gql/client.py", line 1337, in _subscribe
...<11 lines>...
yield result
File "/usr/local/lib/python3.14/site-packages/gql/transport/common/base.py", line 298, in subscribe
answer_type, execution_result = await listener.get()
File "/usr/local/lib/python3.14/site-packages/gql/transport/common/listener_queue.py", line 35, in get
raise item
gql.transport.exceptions.TransportServerError: No pong received after 15.0 seconds
Logger: tibber.realtime
Quelle: runner.py:289
Erstmals aufgetreten: 01:57:17 (106 Vorkommnisse)
Zuletzt protokolliert: 09:50:38
Watchdog: Connection is down, 2026-04-18 07:30:27.822147+00:00
Watchdog: Connection is down, 2026-04-18 07:35:32.981688+00:00
Watchdog: Connection is down, 2026-04-18 07:40:38.157042+00:00
Watchdog: Connection is down, 2026-04-18 07:45:43.323766+00:00
Watchdog: Connection is down, 2026-04-18 07:50:48.504349+00:00
Quelle: /usr/local/lib/python3.14/site-packages/tibber/realtime.py:198
Erstmals aufgetreten: 01:57:48 (104 Vorkommnisse)
Error in watchdog connect, retrying in 300 seconds, 101: Error trying to receive data: ConnectionClosedError
Error in watchdog connect, retrying in 300 seconds, 102: Error trying to receive data: ConnectionClosedError
Error in watchdog connect, retrying in 300 seconds, 103: Error trying to receive data: ConnectionClosedError
Error in watchdog connect, retrying in 300 seconds, 104: Error trying to receive data: ConnectionClosedError
Error in watchdog connect, retrying in 300 seconds, 105: Error trying to receive data: ConnectionClosedError
File "/usr/local/lib/python3.14/site-packages/gql/transport/common/adapters/websockets.py", line 114, in receive
data = await self.websocket.recv()
File "/usr/local/lib/python3.14/site-packages/websockets/asyncio/connection.py", line 322, in recv
raise self.protocol.close_exc from self.recv_exc
websockets.exceptions.ConnectionClosedError: received 4403 (private use) Invalid token; then sent 4403 (private use) Invalid token
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.14/site-packages/tibber/realtime.py", line 190, in _watchdog
self.session = await self.sub_manager.connect_async()
File "/usr/local/lib/python3.14/site-packages/gql/client.py", line 782, in connect_async
await self.session.connect()
File "/usr/local/lib/python3.14/site-packages/gql/client.py", line 1851, in connect
raise e
File "/usr/local/lib/python3.14/site-packages/gql/client.py", line 1848, in connect
await self.transport.connect()
File "/usr/local/lib/python3.14/site-packages/gql/transport/common/base.py", line 402, in connect
raise e
File "/usr/local/lib/python3.14/site-packages/gql/transport/common/base.py", line 400, in connect
await self._initialize()
File "/usr/local/lib/python3.14/site-packages/gql/transport/websockets_protocol.py", line 156, in _initialize
await self._send_init_message_and_wait_ack()
File "/usr/local/lib/python3.14/site-packages/gql/transport/websockets_protocol.py", line 153, in _send_init_message_and_wait_ack
await asyncio.wait_for(self._wait_ack(), self.ack_timeout)
File "/usr/local/lib/python3.14/asyncio/tasks.py", line 488, in wait_for
return await fut
File "/usr/local/lib/python3.14/site-packages/gql/transport/websockets_protocol.py", line 128, in _wait_ack
init_answer = await self._receive()
File "/usr/local/lib/python3.14/site-packages/tibber/websocket_transport.py", line 49, in _receive
msg = await asyncio.wait_for(super()._receive(), timeout=self._timeout)
return await fut
File "/usr/local/lib/python3.14/site-packages/gql/transport/common/base.py", line 153, in _receive
answer: str = await self.adapter.receive()
File "/usr/local/lib/python3.14/site-packages/gql/transport/common/adapters/websockets.py", line 116, in receive
raise TransportConnectionFailed(
f"Error trying to receive data: {type(e).__name__}"
) from e
gql.transport.exceptions.TransportConnectionFailed: Error trying to receive data: ConnectionClosedError
Logs from my modem
04/18/26 01:56:55 Internet connection established successfully. IPv4 is being used via DS-Lite. AFTR gateway: XXXXXX.de, IPv4 MTU: 1500, Broadband PoP: XXXXXX, LineID: XXXXXXX
04/18/26 01:56:55 IPv6 prefix successfully obtained. New prefix: XXXXXXXX
04/18/26 01:56:55 IPv6 Internet connection successfully established. IP address: XXXXXXX
04/18/26 01:56:52 Internet connection disconnected.
04/18/26 01:56:52 IPv6 internet connection disconnected, prefix no longer valid.
04/18/26 01:56:52 The internet connection is being briefly interrupted to preempt forced disconnection by the provider.
<img width="466" height="559" alt="Image" src="https://github.com/user-attachments/assets/f522dc91-dec5-4279-9987-8be51b4a5096" />
### What version of Home Assistant Core has the issue?
core-2026.4.3
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
Tibber
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/tibber
### Diagnostics information
_No response_
### Example YAML snippet
```yaml
### Anything in the logs that might be useful for us?
```txt
### Additional information
Another issue is described in #168007. The recommendation was to create a new ticket.
