Ich habe 3 Gledopto GL-C-008P bei mir fest verbaut, heisst ich komme nur mit erheblichen, destruktivem Aufwand wieder dran um den Reset Knopf zu drücken.
Wäre es theoretisch möglich, die Geräte mittels editieren der Konfiguration Files wieder ins Netz zu bekommen?
Ich habe die alte Konfiguration gesichert und in der configuration.yaml im zigbee2mqtt Ordner sehen die Einträge so aus: (Beispiel an einem baugleichen Endgerät)
devices:
'0xa4c1385ceac93e13':
friendly_name: OG Wandverbau
Müsste doch theoretisch möglich sein oder?
In der database.db drin steht folgendes
alte Version:
{"id":141,"type":"Router","ieeeAddr":"0xa4c1385ceac93e13","nwkAddr":16334,"manufId":4687,"manufName":"GLEDOPTO","powerSource":"Mains (single phase)","modelId":"GL-C-008P","epList":[11,242],"endpoints":{"11":{"profId":260,"epId":11,"devId":269,"inClusterList":[0,3,4,5,6,8,768,4096],"outClusterList":[25],"clusters":{"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":158,"colorTempPhysicalMax":495,"colorMode":2,"currentX":0,"currentY":0,"enhancedCurrentHue":0,"currentSaturation":0,"colorTemperature":285}},"genBasic":{"attributes":{"modelId":"GL-C-008P","manufacturerName":"GLEDOPTO"}},"genOnOff":{"attributes":{"onOff":0}},"genLevelCtrl":{"attributes":{"currentLevel":254}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20230605","swBuildId":"20351203","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1324213189},"lastSeen":1742629085367}
aktuelle Version:
{"id":20,"type":"Router","ieeeAddr":"0xa4c1385ceac93e13","nwkAddr":40554,"manufId":4687,"manufName":"GLEDOPTO","powerSource":"Mains (single phase)","modelId":"GL-C-008P","epList":[11,242],"endpoints":{"11":{"profId":260,"epId":11,"devId":269,"inClusterList":[0,3,4,5,6,8,768,4096],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"GL-C-008P","manufacturerName":"GLEDOPTO","powerSource":1,"zclVersion":3,"appVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20230605","swBuildId":"20351203"}},"lightingColorCtrl":{"attributes":{"colorCapabilities":31,"colorTempPhysicalMin":158,"colorTempPhysicalMax":495}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20230605","swBuildId":"20351203","zclVersion":3,"interviewCompleted":true,"meta":{"configured":332242049},"lastSeen":1742654364063}
Hat das schon mal Jemand gemacht?
Womit bearbeitet man die database.db am besten?
