Wie gesagt: Wenn ich die Temperatur komplett aus der Automation raus nehme und nur “Fenster auf” setze, bleibt der Fehler.
Hier mal das MQTT Log:
debug 2024-02-10 19:52:17Received Zigbee message from 'Testkontakt', type 'commandStatusChangeNotification', cluster 'ssIasZone', data '{"extendedstatus":0,"zonestatus":1}' from endpoint 1 with groupID 0
info 2024-02-10 19:52:17MQTT publish: topic 'zigbee2mqtt/Testkontakt', payload '{"battery":100,"battery_low":false,"contact":false,"last_seen":"2024-02-10T19:52:17+01:00","linkquality":54,"tamper":false,"voltage":3300}'
debug 2024-02-10 19:52:22Received MQTT message on 'zigbee2mqtt/Heizung Arbeitszimmer Martin/set/open_window' with data 'ON'
debug 2024-02-10 19:52:22Publishing 'set' 'open_window' to 'Heizung Arbeitszimmer Martin'
debug 2024-02-10 19:52:22Received MQTT message on 'zigbee2mqtt/Heizung Arbeitszimmer Martin/set/open_window_temperature' with data '5'
debug 2024-02-10 19:52:22Publishing 'set' 'open_window_temperature' to 'Heizung Arbeitszimmer Martin'
info 2024-02-10 19:52:24MQTT publish: topic 'zigbee2mqtt/Heizung Arbeitszimmer Martin', payload '{"battery_low":false,"boost_timeset_countdown":0,"child_lock":"UNLOCK","comfort_temperature":22,"current_heating_setpoint":30,"eco_temperature":18,"error_status":0,"frost_protection":"OFF","heating_stop":"OFF","holiday_start_stop":"2021/01/01 01:01 | 2021/01/01 01:01","holiday_temperature":17,"last_seen":"2024-02-10T19:48:33+01:00","linkquality":123,"local_temperature":21.2,"local_temperature_calibration":0,"online":"ON","open_window":"ON","open_window_temperature":5,"preset":"manual","schedule_friday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_monday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_saturday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_sunday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_thursday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_tuesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_wednesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","system_mode":"heat","update":{"installed_version":69,"latest_version":-1,"state":"idle"},"update_available":false,"working_day":"mon_sun"}'
debug 2024-02-10 19:52:24Received Zigbee message from 'Heizung Arbeitszimmer Martin', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":1,"dp":8}],"seq":1}' from endpoint 1 with groupID 0
info 2024-02-10 19:52:24MQTT publish: topic 'zigbee2mqtt/Heizung Arbeitszimmer Martin', payload '{"battery_low":false,"boost_timeset_countdown":0,"child_lock":"UNLOCK","comfort_temperature":22,"current_heating_setpoint":30,"eco_temperature":18,"error_status":0,"frost_protection":"OFF","heating_stop":"OFF","holiday_start_stop":"2021/01/01 01:01 | 2021/01/01 01:01","holiday_temperature":17,"last_seen":"2024-02-10T19:52:24+01:00","linkquality":123,"local_temperature":21.2,"local_temperature_calibration":0,"online":"ON","open_window":"ON","open_window_temperature":5,"preset":"manual","schedule_friday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_monday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_saturday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_sunday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_thursday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_tuesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_wednesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","system_mode":"heat","update":{"installed_version":69,"latest_version":-1,"state":"idle"},"update_available":false,"working_day":"mon_sun"}'
debug 2024-02-10 19:52:24Received Zigbee message from 'Heizung Arbeitszimmer Martin', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":1,"dp":8}],"seq":257}' from endpoint 1 with groupID 0
debug 2024-02-10 19:52:24Received Zigbee message from 'Heizung Arbeitszimmer Martin', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0],"type":"Buffer"},"datatype":1,"dp":8}],"seq":513}' from endpoint 1 with groupID 0
info 2024-02-10 19:52:24MQTT publish: topic 'zigbee2mqtt/Heizung Arbeitszimmer Martin', payload '{"battery_low":false,"boost_timeset_countdown":0,"child_lock":"UNLOCK","comfort_temperature":22,"current_heating_setpoint":30,"eco_temperature":18,"error_status":0,"frost_protection":"OFF","heating_stop":"OFF","holiday_start_stop":"2021/01/01 01:01 | 2021/01/01 01:01","holiday_temperature":17,"last_seen":"2024-02-10T19:52:24+01:00","linkquality":120,"local_temperature":21.2,"local_temperature_calibration":0,"online":"ON","open_window":"OFF","open_window_temperature":5,"preset":"manual","schedule_friday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_monday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_saturday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_sunday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_thursday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_tuesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_wednesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","system_mode":"heat","update":{"installed_version":69,"latest_version":-1,"state":"idle"},"update_available":false,"working_day":"mon_sun"}'
debug 2024-02-10 19:52:25Received Zigbee message from 'Heizung Arbeitszimmer Martin', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":2}],"seq":769}' from endpoint 1 with groupID 0
info 2024-02-10 19:52:25MQTT publish: topic 'zigbee2mqtt/Heizung Arbeitszimmer Martin', payload '{"battery_low":false,"boost_timeset_countdown":0,"child_lock":"UNLOCK","comfort_temperature":22,"current_heating_setpoint":30,"eco_temperature":18,"error_status":0,"frost_protection":"OFF","heating_stop":"OFF","holiday_start_stop":"2021/01/01 01:01 | 2021/01/01 01:01","holiday_temperature":17,"last_seen":"2024-02-10T19:52:25+01:00","linkquality":123,"local_temperature":21.2,"local_temperature_calibration":0,"online":"ON","open_window":"OFF","open_window_temperature":5,"preset":"manual","schedule_friday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_monday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_saturday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_sunday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_thursday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_tuesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","schedule_wednesday":"06:00/17 12:00/21 14:00/17 17:00/21 24:00/17","system_mode":"heat","update":{"installed_version":69,"latest_version":-1,"state":"idle"},"update_available":false,"working_day":"mon_sun"}'
debug 2024-02-10 19:52:25Received Zigbee message from 'Heizung Arbeitszimmer Martin', type 'commandDataResponse', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,50],"type":"Buffer"},"datatype":2,"dp":102}],"seq":1}' from endpoint 1 with groupID 0
Gerade noch einmal probiert. Es bleibt bei dem Fehler.
nächster Nachtrag:
OK, ich hab jetzt mal die Aktion geändert. Statt im Thermostat den Status von “Window Open” von OFF nach ON zu ändern, hab ich jetzt in der Automation den Status von “Heating Stop” von OFF nach ON geändert. Im Prinzip für mich der gleiche Effekt.
Das funktioniert. Beide Eigenschaften sind als Entity vom Typ Switch definiert. Scheinbar ist da was in der Implementierung des Rollei/ TuYa TV02 nicht in Ordnung. Oder ich mache noch einen Fehler.
und noch eine Erkentnis:
Es scheint ein Problem des Thermostats zu sein. Wenn ich den Modus “Window open” manuell im zigbee2mqtt Dashboard für das Gerät schalte, dann springt das auch sofort wieder zurück. Auf Github gibt es auch Hinweise auf Probleme mit Window open
Einmal Batterien raus aus dem Thermostat und nun geht es wieder. Mal sehen wie lange.
