Log:
debug 2023-04-09 20:04:53Received Zigbee message from '0xa4c1384a7adf9a3c', type 'raw', cluster 'manuSpecificBosch', data '{"data":[8,129,10,1,208,72,2,0,6],"type":"Buffer"}' from endpoint 1 with groupID 0
debug 2023-04-09 20:04:53No converter available for 'TS011F_plug_1' with cluster 'manuSpecificBosch' and type 'raw' and data '{"data":[8,129,10,1,208,72,2,0,6],"type":"Buffer"}'
debug 2023-04-09 20:04:54Received Zigbee message from '0xa4c1384a7adf9a3c', type 'raw', cluster 'manuSpecificBosch', data '{"data":[8,129,10,1,208,72,2,0,6],"type":"Buffer"}' from endpoint 1 with groupID 0
debug 2023-04-09 20:04:54No converter available for 'TS011F_plug_1' with cluster 'manuSpecificBosch' and type 'raw' and data '{"data":[8,129,10,1,208,72,2,0,6],"type":"Buffer"}'
debug 2023-04-09 20:04:55Received Zigbee message from '0xa4c1384a7adf9a3c', type 'raw', cluster 'manuSpecificBosch', data '{"data":[8,130,10,2,208,72,2,0,10],"type":"Buffer"}' from endpoint 1 with groupID 0
debug 2023-04-09 20:04:55No converter available for 'TS011F_plug_1' with cluster 'manuSpecificBosch' and type 'raw' and data '{"data":[8,130,10,2,208,72,2,0,10],"type":"Buffer"}'
debug 2023-04-09 20:04:55Received Zigbee message from '0xa4c1384a7adf9a3c', type 'attributeReport', cluster 'genOnOff', data '{"32768":0,"moesStartUpOnOff":2,"offWaitTime":0,"onOff":1,"onTime":0,"tuyaBacklightMode":1,"tuyaBacklightSwitch":1}' from endpoint 1 with groupID 0
info 2023-04-09 20:04:55MQTT publish: topic 'zigbee2mqtt/0xa4c1384a7adf9a3c', payload '{"child_lock":"UNLOCK","current":null,"energy":null,"indicator_mode":"off/on","linkquality":129,"power":null,"power_outage_memory":"restore","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":"available"},"update_available":null,"voltage":null}'
debug 2023-04-09 20:04:55Received Zigbee message from '0xa4c1384a7adf9a3c', type 'attributeReport', cluster 'manuSpecificTuya_3', data '{"powerOnBehavior":2,"switchType":0}' from endpoint 1 with groupID 0
debug 2023-04-09 20:04:55No converter available for 'TS011F_plug_1' with cluster 'manuSpecificTuya_3' and type 'attributeReport' and data '{"powerOnBehavior":2,"switchType":0}'
debug 2023-04-09 20:04:55Received Zigbee message from '0xa4c1384a7adf9a3c', type 'attributeReport', cluster 'genOnOff', data '{"offWaitTime":0,"onOff":1,"onTime":0}' from endpoint 2 with groupID 0
debug 2023-04-09 20:04:55Received Zigbee message from '0xa4c1384a7adf9a3c', type 'attributeReport', cluster 'manuSpecificTuya_3', data '{"powerOnBehavior":2}' from endpoint 2 with groupID 0
debug 2023-04-09 20:04:55No converter available for 'TS011F_plug_1' with cluster 'manuSpecificTuya_3' and type 'attributeReport' and data '{"powerOnBehavior":2}'
debug 2023-04-09 20:04:55Received Zigbee message from '0xa4c1384a7adf9a3c', type 'read', cluster 'genTime', data '["localTime"]' from endpoint 1 with groupID 0
debug 2023-04-09 20:04:56Received Zigbee message from '0xa4c1384a7adf9a3c', type 'raw', cluster 'manuSpecificBosch', data '{"data":[8,136,10,1,208,72,2,0,6],"type":"Buffer"}' from endpoint 1 with groupID 0
debug 2023-04-09 20:04:56No converter available for 'TS011F_plug_1' with cluster 'manuSpecificBosch' and type 'raw' and data '{"data":[8,136,10,1,208,72,2,0,6],"type":"Buffer"}'
debug 2023-04-09 20:04:57Received Zigbee message from '0xa4c1384a7adf9a3c', type 'raw', cluster 'manuSpecificBosch', data '{"data":[8,137,10,2,208,72,2,0,10],"type":"Buffer"}' from endpoint 1 with groupID 0
debug 2023-04-09 20:04:57No converter available for 'TS011F_plug_1' with cluster 'manuSpecificBosch' and type 'raw' and data '{"data":[8,137,10,2,208,72,2,0,10],"type":"Buffer"}'
debug 2023-04-09 20:05:39Received MQTT message on 'zigbee2mqtt/0xa4c1384a7adf9a3c/set' with data '{"state":"OFF"}'
debug 2023-04-09 20:05:39Publishing 'set' 'state' to '0xa4c1384a7adf9a3c'
info 2023-04-09 20:05:39MQTT publish: topic 'zigbee2mqtt/0xa4c1384a7adf9a3c', payload '{"child_lock":"UNLOCK","current":null,"energy":null,"indicator_mode":"off/on","linkquality":99,"power":null,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":"available"},"update_available":null,"voltage":null}'
debug 2023-04-09 20:05:39Received Zigbee message from '0xa4c1384a7adf9a3c', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2023-04-09 20:05:39MQTT publish: topic 'zigbee2mqtt/0xa4c1384a7adf9a3c', payload '{"child_lock":"UNLOCK","current":null,"energy":null,"indicator_mode":"off/on","linkquality":90,"power":null,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":"available"},"update_available":null,"voltage":null}'
debug 2023-04-09 20:05:39Received Zigbee message from '0xa4c1384a7adf9a3c', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 2 with groupID 0
info 2023-04-09 20:05:39MQTT publish: topic 'zigbee2mqtt/0xa4c1384a7adf9a3c', payload '{"child_lock":"UNLOCK","current":null,"energy":null,"indicator_mode":"off/on","linkquality":126,"power":null,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":"available"},"update_available":null,"voltage":null}'
