Einen Development Bereich habe ich hier nicht gefunden, hoffe es passt in diese Kategorie.
Es geht darum, dass ich die Konfiguration über die config_flow.py meiner Integration etwas übersichtlich er gestalten möchte. Dazu wollte ich “Section” verwenden.
async def async_step_init(self, user_input=None):
"""Manage the options."""
if user_input is not None:
# Ensure that empty fields are stored as empty strings
for key in [CONF_ONLYLINE, CONF_HIDEDESTINATION, CONF_ONLYDESTINATION, CONF_DOUBLESTATIONNUMBER,
CONF_TIMEZONE_FROM, CONF_TIMEZONE_TO, CONF_ALERT_FOR, CONF_GLOBALID2]:
if key not in user_input:
user_input[key] = "" # Explicitly set the field to an empty string if it's not in the user_input
# Convert selected transport types to a comma-separated string
if CONF_TRANSPORTTYPES in user_input:
user_input[CONF_TRANSPORTTYPES] = ','.join(user_input[CONF_TRANSPORTTYPES])
# Save the updated data self.config_entry, data={**self.config_entry.data, **user_input}
self.hass.config_entries.async_update_entry(
self.config_entry, data=user_input
# Reload the integration to apply changes
await self.hass.config_entries.async_reload(self.config_entry.entry_id)
return self.async_create_entry(title="", data={})
# Prepare the default values based on current configuration data
current_data = self.config_entry.data
transport_types = DEFAULT_CONF_TRANSPORTTYPES.split(',')
selected_transport_types = current_data.get(CONF_TRANSPORTTYPES, '').split(',')
self.options_schema = vol.Schema({
vol.Required(CONF_NAME, default=current_data.get(CONF_NAME)): str,
vol.Required(CONF_GLOBALID, default=current_data.get(CONF_GLOBALID)): str,
vol.Optional(CONF_TRANSPORTTYPES, default=selected_transport_types): selector({
"select": {
"options": transport_types,
"multiple": True,
"custom_value": True
vol.Optional(CONF_LIMIT, default=current_data.get(CONF_LIMIT, DEFAULT_LIMIT)): int,
vol.Optional(CONF_ONLYLINE, description={"suggested_value": current_data.get(CONF_ONLYLINE, "")}): str,
vol.Optional(CONF_HIDEDESTINATION, description={"suggested_value": current_data.get(CONF_HIDEDESTINATION, "")}): str,
vol.Optional(CONF_ONLYDESTINATION, description={"suggested_value": current_data.get(CONF_ONLYDESTINATION, "")}): str,
# Items can be grouped by collapsible sections
"advanced_options": section(
vol.Schema(
vol.Optional(CONF_HIDENAME, description={"suggested_value": current_data.get(CONF_HIDENAME, "")}): bool,
vol.Optional(CONF_GLOBALID2, description={"suggested_value": current_data.get(CONF_GLOBALID2, "")}): str,
vol.Optional(CONF_DOUBLESTATIONNUMBER, description={"suggested_value": current_data.get(CONF_DOUBLESTATIONNUMBER, "")}): str,
vol.Optional(CONF_TIMEZONE_FROM, description={"suggested_value": current_data.get(CONF_TIMEZONE_FROM, "")}): str,
vol.Optional(CONF_TIMEZONE_TO, description={"suggested_value": current_data.get(CONF_TIMEZONE_TO, "")}): str,
vol.Optional(CONF_ALERT_FOR, description={"suggested_value": current_data.get(CONF_ALERT_FOR, "")}): str,
# Whether or not the section is initially collapsed (default = False)
{"collapsed": True},
return self.async_show_form(
step_id="init",
data_schema=self.options_schema
Das Problem ist jetzt, dass alles was der Section zugeordnet ist nicht mehr gespeichert wird. Auch werden die bisher gespeicherten Werte dort nicht angezeigt.
Entferne ich die Section, funktioniert wieder alles.
"select": {
"multiple": True,
