Automation für Geschirrspüler
Hallo bin ein Anfänger was HA angeht.
Nutze da gern Simons Videos.
Hab soweit Home Connect und mein Geschirrspüler in HA integriert.
Verwende zum Start des Geschirrspülers Simon seine Automation die bei mir nicht laufen will.
Angepasste Automation:
alias: Energy - Run Dishwasher at Sun Prime Time
trigger:
  - platform: state
      - input_button.vorwahl_spuhlmaschine_eco
    variables:
      dishwasher_mode: switch.geschirrspuler_program_eco50
  - platform: state
      - input_button.vorwahl_spulmaschine_auto
    variables:
      dishwasher_mode: switch.geschirrspuler_program_auto2
condition: []
action:
  - choose:
      - conditions:
          - condition: template
            value_template: >-
              {{ as_timestamp(states("sensor.power_highest_peak_time_today")) >=
              as_timestamp(now()) }}
        sequence:
          - service: input_datetime.set_datetime
              timestamp: >-
                {{ as_timestamp(states('sensor.power_highest_peak_time_today'))
              entity_id: input_datetime.nachste_startzeit_spulmaschine
      - conditions:
          - condition: or
            conditions:
              - condition: numeric_state
                entity_id: sensor.energy_current_hour
                above: 0.3
                entity_id: sensor.energy_next_hour
                above: 0.3
                entity_id: sensor.shelly_solar_power
                above: 300
        sequence:
              timestamp: "{{ now().timestamp() }}"
    default:
          timestamp: >-
            {{ as_timestamp(states('sensor.power_highest_peak_time_tomorrow'))
  - service: homeassistant.turn_on
    data: {}
      entity_id: switch.geschirrspuler_power
  - delay:
      hours: 0
      minutes: 0
      seconds: 30
      milliseconds: 0
  - service: home_connect.start_program
    metadata: {}
      device_id: 131a0f14098dade218fb030be005f9a6
      entity_id: "{{ dishwasher_mode }}\""
      key: BSH.Common.Option.StartInRelative
      value: >-
        (as_datetime(states("input_datetime.nachste_startzeit_spulmaschine")).astimezone()
        -  now()).seconds | int }}
Wenn ich die Automation starte bekomme ich folgende Fehlermeldung in den Traces angezeigt:
Ausgeführt: 21. April 2024 um 13:48:04
Fehler: extra keys not allowed @ data['entity_id']
Ergebnis:
params:
  domain: home_connect
  service: start_program
  service_data:
    entity_id: switch.geschirrspuler_program_auto2"
    value: 83515
  target: {}
running_script: false
Könnt ihr mir bitte bei einer Lösung helfen?`
mfg
Liegt es vielleicht an den " bei der entity_id?
hab mir die entity_id so raus kopiert wie ich die über HA manuell starte
extra key not allowed…
lass doch mal diese Zeile weg
Aber doch sicherlich nicht mit dem " am Ende
Die entity_id war schon korrekt kopiert. bei der Ausgabe haben zwei Zeichen verirrt.
Leider aber immer noch das selbe Ergebniss.
Ausgeführt: 22. April 2024 um 15:16:05
Ergebnis:
params:
  service_data:
    value: 67434
  target: {}
Da der Geschirrspüler zu einer gewissen Zeit starten soll, ist der Befehl meiner Ansicht nach unverzichtbar.
Den Fehler in der entity_id-Zeile hast du auch korrigiert?
Ja, \ und einmal ", rausgenommen
Hab nun auch bei “dishwasher_mode” die Korrekten Variablen genommen die in der Home-connect Doku erlaubt sind.
edit:
Nun im code
metadata: {}
rausgeschmissen.
…und
entity_id: "{{ dishwasher_mode }}"
in
program: "{{ dishwasher_mode }}"
geändert. Siehe da kein Fehler mehr.
Die Logs sagen nun auch folgendes:
