Die Logs sind quasi voll damit wenn ich die integration setupen will, so dass er immer in einen Timeout gerät wenn ich die Zugangsdaten zur Switchbot Verbindung herstellen will.
Ich habe das Gefühl das etwas mit dem Addon nicht richtig ist und es einen bug gibt.
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.12/site-packages/bleak_retry_connector/init.py", line 363, in establish_connection
await client.connect(
File "/usr/local/lib/python3.12/site-packages/habluetooth/wrappers.py", line 310, in connect
connected = await super().connect(**kwargs)
File "/usr/local/lib/python3.12/site-packages/bleak/init.py", line 615, in connect
return await self._backend.connect(**kwargs)
File "/usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/client.py", line 151, in connect
async with async_timeout(timeout):
File "/usr/local/lib/python3.12/asyncio/timeouts.py", line 115, in aexit
raise TimeoutError from exc_val
TimeoutError
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 368, in async_configure
result = await self._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 415, in _async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 518, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/switchbot/config_flow.py", line 198, in async_step_lock_auth
return await self.async_step_lock_key(key_details)
File "/usr/src/homeassistant/homeassistant/components/switchbot/config_flow.py", line 239, in async_step_lock_key
if not await SwitchbotLock.verify_encryption_key(
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/lock.py", line 101, in verify_encryption_key
lock_info = await lock.get_basic_info()
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/lock.py", line 257, in get_basic_info
lock_raw_data = await self._get_lock_info()
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/lock.py", line 299, in _get_lock_info
_data = await self._send_command(
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/lock.py", line 356, in _send_command
result = await self._ensure_encryption_initialized()
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/lock.py", line 371, in _ensure_encryption_initialized
result = await self._send_command(
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/lock.py", line 354, in _send_command
return await super()._send_command(key[:2] + "000000" + key[2:], retry)
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/device.py", line 185, in _send_command
return await self._send_command_locked(key, command)
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/device.py", line 419, in _send_command_locked
await self._ensure_connected()
File "/usr/local/lib/python3.12/site-packages/switchbot/devices/device.py", line 279, in _ensure_connected
client: BleakClientWithServiceCache = await establish_connection(
File "/usr/local/lib/python3.12/site-packages/bleak_retry_connector/init.py", line 387, in establish_connection
_raise_if_needed(name, device.address, exc)
File "/usr/local/lib/python3.12/site-packages/bleak_retry_connector/init.py", line 327, in _raise_if_needed
raise BleakNotFoundError(msg) from exc
bleak_retry_connector.BleakNotFoundError: D5-3E-63-87-40-3A (D5:3E:63:87:40:3A) - D5:3E:63:87:40:3A: Failed to connect after 6 attempt(s): TimeoutError```
