Ich habe mal in der config einzelne entities explizit eingeschlossen.
alexa:
smart_home:
endpoint: https://api.amazonalexa.com/v3/events
filter:
include_entities:
- climate.heizung_schlafzimmer
- sensor.schlafzimmer_temperatur
- climate.heizung_badezimmer
- sensor.badezimmer_temperatur
Wenn ich in der AWS Konsole dann den discovery teste, werden die anscheinend auch korrekt gefunden. Aber warum findet die Alexa-App keine Geräte und verbindet sich nicht?
"event": {
"header": {
"namespace": "Alexa.Discovery",
"name": "Discover.Response",
"messageId": "3b47a4f6-ddc7-4dfd-95a6-f4bb4960537b",
"payloadVersion": "3"
"payload": {
"endpoints": [
"displayCategories": [
"TEMPERATURE_SENSOR"
"cookie": {},
"endpointId": "sensor#badezimmer_temperatur",
"friendlyName": "Badezimmer_Temperatur",
"description": "sensor.badezimmer_temperatur via Home Assistant",
"manufacturerName": "Home Assistant",
"additionalAttributes": {
"manufacturer": "Home Assistant",
"model": "sensor",
"softwareVersion": "2024.2.2",
"customIdentifier": "-sensor.badezimmer_temperatur"
"capabilities": [
"type": "AlexaInterface",
"interface": "Alexa.TemperatureSensor",
"version": "3",
"properties": {
"supported": [
"name": "temperature"
"proactivelyReported": true,
"retrievable": true
"interface": "Alexa.EndpointHealth",
"version": "3",
"properties": {
"supported": [
"name": "connectivity"
"retrievable": true
"interface": "Alexa",
"version": "3"
"cookie": {},
"endpointId": "sensor#schlafzimmer_temperatur",
"friendlyName": "Schlafzimmer_Temperatur",
"description": "sensor.schlafzimmer_temperatur via Home Assistant",
"model": "sensor",
"customIdentifier": "-sensor.schlafzimmer_temperatur"
"capabilities": [
"version": "3",
"properties": {
"supported": [
"retrievable": true
"version": "3",
"properties": {
"supported": [
"retrievable": true
"version": "3"
"THERMOSTAT"
"cookie": {},
"endpointId": "climate#heizung_badezimmer",
"friendlyName": "Heizung Badezimmer",
"description": "climate.heizung_badezimmer via Home Assistant",
"model": "climate",
"customIdentifier": "-climate.heizung_badezimmer"
"capabilities": [
"interface": "Alexa.PowerController",
"version": "3",
"properties": {
"supported": [
"name": "powerState"
"retrievable": true
"interface": "Alexa.ThermostatController",
"version": "3",
"properties": {
"supported": [
"name": "thermostatMode"
"name": "targetSetpoint"
"retrievable": true
"configuration": {
"supportsScheduling": false,
"supportedModes": [
"OFF",
"AUTO",
"AUTO",
"HEAT"
"version": "3",
"properties": {
"supported": [
"retrievable": true
"version": "3",
"properties": {
"supported": [
"retrievable": true
"version": "3"
"THERMOSTAT"
"cookie": {},
"endpointId": "climate#heizung_schlafzimmer",
"friendlyName": "Heizung Schlafzimmer",
"description": "climate.heizung_schlafzimmer via Home Assistant",
"model": "climate",
"customIdentifier": "-climate.heizung_schlafzimmer"
"capabilities": [
"version": "3",
"properties": {
"supported": [
"retrievable": true
"version": "3",
"properties": {
"supported": [
"retrievable": true
"configuration": {
"supportedModes": [
"AUTO",
"HEAT",
"OFF"
"version": "3",
"properties": {
"supported": [
"retrievable": true
"version": "3",
"properties": {
"supported": [
"retrievable": true
"version": "3"
