Advanced SSH & Web Terminal startet nicht
Hallo zusammen. Ich kriege das Add On
nicht gestartet. Es kommt immer diese Fehlermeldung: 1
wenn ich dann auf AddOn starten klicke kommt das:
2
Wäre über Tipps dankbar :slight_smile:
Hallo Dennis,
die Infos sind etwas “dünn”:
Wo läuft HA? Welche Version hat HA?
Hallo Ronny. Ich bin komplett neu. Alles heute neu aufgesetzt. HA läuft auf einem Intel NUC.
Eigentlich solltest Du unter “Einstellungen” - “Add-ons” - “Terminal & SSH” und dann “Protokoll” einige Infos finden…
Schick die doch mal hier rein…
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Advanced SSH & Web Terminal
A supercharged SSH & Web Terminal access to your Home Assistant instance
Add-on version: 17.0.3
You are running the latest version of this add-on.
System: Home Assistant OS 11.4 (amd64 / generic-x86-64)
Home Assistant Core: 2024.1.2
Home Assistant Supervisor: 2023.12.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-user: starting
s6-rc: info: service init-ssh: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-docker: starting
s6-rc: info: service init-mosquitto successfully started
[13:46:07] INFO: Docker support has been enabled.
[13:46:07] WARNING:
s6-rc: info: service init-mysql successfully started
s6-rc: info: service init-docker successfully started
[13:46:07] WARNING: Logging in with a SSH password is security wise, a bad idea!
[13:46:07] WARNING: Please, consider using a public/private key pair.
[13:46:07] WARNING: What is this? Set up SSH public key authentication to connect to a remote system
[13:46:07] WARNING:
adduser: illegal character with code 195 at position 2
[13:46:07] FATAL: Failed creating the user account
s6-rc: warning: unable to start service init-ssh: command exited 1
[13:46:07] NOTICE: Session sharing has been disabled!
s6-rc: info: service init-user successfully started
s6-rc: info: service ttyd: starting
s6-rc: info: service ttyd successfully started
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service init-mysql: stopping
s6-rc: info: service init-mosquitto: stopping
s6-rc: info: service init-docker: stopping
s6-rc: info: service ttyd: stopping
s6-rc: info: service init-mosquitto successfully stopped
s6-rc: info: service init-mysql successfully stopped
s6-rc: info: service init-docker successfully stopped
[13:46:07] INFO: Service ttyd exited with code 256 (by signal 15)
s6-rc: info: service ttyd successfully stopped
s6-rc: info: service init-user: stopping
s6-rc: info: service init-user successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Evtl. liegt es am User
Was muss ich dann machen?!
Was hast du denn in der Addon-Konfiguration als User und Password angegeben?
Ja na Character code 195 ist so ein A mit einem Schnickel drüber.
Der Benutzer sollte micht mit einem Sonderzeichen anfangen - evtl. liegt auch nur ein Tippfehler vor.
Unter “Einstellungen” - “Personen” und dann oben auf “Benutzer” klicken siehst Du alle Benutzer. Dein Benutzer sollte zumindest in der Spalte “Benutzername” einen Namen ohne Sonderzeichen haben - so könnte man sich der Problematik nähern…
Vielleicht schaust du dir das Short-Video von simon42 mal an:
Da sieht man im Screenshot auch den Usernamen.
username: dkönig
password: HFCtFHM68JoVgu
So habe ich es stehen. PW ist ein generiertes.
bitte keine Umlaute im Usernamen.
Und auch mal das Video schauen.
Es lag tatsächlich am Ö. Danke. Problem gelöst. :slight_smile:
Hallo, Ich habe ein ähnliches Problem, bei mir kommt ein Fehler wenn ich das Passwort speichern möchte.
Fehler beim Speichern der Add-on Konfiguration, Unknown error, see supervisor logs
Was habe ich Falsch gemacht?
Was sagen denn den supervisor Logs?
Hast du schon einmal ein “einfaches” Kennwort, wie z.B. “Kennwort.1234” probiert - also ohne Sonderzeichen, Umlaute usw.?
Kennwort 1234 habe ich versucht, benutzer so wie er vorgeschlagen wird.
das hier steht im log:
Add-on version: 19.0.0
System: Home Assistant OS 13.2 (amd64 / qemux86-64)
Home Assistant Core: 2024.11.3
Home Assistant Supervisor: 2024.11.4
[12:47:46] FATAL:
[12:47:46] FATAL: Configuration of this add-on is incomplete.
[12:47:46] FATAL:
[12:47:46] FATAL: Please be sure to set at least an SSH password
[12:47:46] FATAL: or at least one authorized key!
[12:47:46] FATAL:
[12:47:46] FATAL: You can configure this using the "ssh.password"
[12:47:46] FATAL: or the "ssh.authorized_keys" option in the
[12:47:46] FATAL: add-on configuration.
[12:47:46] FATAL:
Die Konfiguration ist falsch bzw. unvollständig.
Lass doch mal bitte Deine Konfiguration sehen.
username: hassio
password: ""
authorized_keys: []
sftp: false
compatibility_mode: false
allow_agent_forwarding: false
allow_remote_port_forwarding: false
allow_tcp_forwarding: false
:crayon:by HarryP:
. Zusammenführung Doppelpost (bitte “bearbeiten” Funktion nutzen)
Beim Passwort hast du hoffentlich keine “” drin
username: hassio
password: 1234Abc
authorized_keys: []
sftp: false
ich habe die VM gelöscht und noch einmal neu aufgesetzt, jetzt geht es.
