Advanced SSH startet nicht
als kompletter Neuling in HA habe ich natürlich gleich mal ein Problem, das mich nicht wirklich weiter machen lässt. :grimacing:
Ich habe den Advance SSH installiert, dieser startet aber leider nicht.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: Advanced SSH & Web Terminal
 A supercharged SSH & Web Terminal access to your Home Assistant instance
 Add-on version: 14.0.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.1  (amd64 / qemux86-64)
 Home Assistant Core: 2023.4.6
 Home Assistant Supervisor: 2023.04.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-user: starting
s6-rc: info: service init-ssh: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-docker: starting
s6-rc: info: service init-docker successfully started
s6-rc: info: service init-mosquitto successfully started
s6-rc: info: service init-mysql successfully started
/etc/s6-overlay/s6-rc.d/init-user/run: line 55: /data/.ssh/environment: No such file or directory
[17:46:34] FATAL: Failed to set Supervisor API token in env
s6-rc: warning: unable to start service init-user: command exited 1
[17:46:34] WARNING:
[17:46:34] WARNING: Logging in with a SSH password is security wise, a bad idea!
[17:46:34] WARNING: Please, consider using a public/private key pair.
[17:46:34] WARNING: What is this? https://kb.iu.edu/d/aews
[17:46:34] WARNING:
s6-rc: info: service init-ssh successfully started
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service init-mysql: stopping
s6-rc: info: service init-mosquitto: stopping
s6-rc: info: service init-docker: stopping
s6-rc: info: service init-ssh: stopping
s6-rc: info: service init-mosquitto successfully stopped
s6-rc: info: service init-mysql successfully stopped
s6-rc: info: service init-docker successfully stopped
s6-rc: info: service init-ssh successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
HAOS läuft auf einem Futjisu Mini PCin einer Proxmox VM.
Würde ja gerne in die uncaught-logs schauen, aber mit dem File Editor komme ich da nicht. Wieder Bildschirm und Tastarur anschließen?
Das Add-on Terminal SSH startet ohne Probs.
Jemand eine Idee?
so sieht es bei mir auch so aus. Mal sehen, ob jemand eine Idee hat.
Es kam gerade ein Update auf 14.0.1 … eventuell löst das ja das Problem.
Ja, das hat das Problem scheinbar gelöst. Bei öffnet sich nun das Terminal :slight_smile:
Hallo bei mir geht es auch nicht SSH Ver. 17.0.1
Wlecher user muß eingertagen werden ?
ich melde mich am PC mit meiner Emailadresse an ?
Add-on version: 17.0.1
System: Home Assistant OS 11.2 (amd64 / generic-x86-64)
Home Assistant Core: 2023.12.4
Home Assistant Supervisor: 2023.12.0
[14:32:33] NOTICE: Session sharing has been disabled!
s6-rc: info: service init-user successfully started
s6-rc: info: service ttyd: starting
s6-rc: info: service ttyd successfully started
[14:32:33] WARNING:
[14:32:33] WARNING: Logging in with a SSH password is security wise, a bad idea!
[14:32:34] WARNING: Please, consider using a public/private key pair.
[14:32:34] WARNING: What is this? IU Knowledge Home - IUKB
[14:32:34] WARNING:
[14:32:34] INFO: Starting the ttyd daemon…
s6-rc: info: service sshd: starting
s6-rc: info: service sshd successfully started
s6-rc: info: service legacy-services: starting
[14:32:34] INFO: Starting the SSH daemon…
Server listening on 0.0.0.0 port 22.
Server listening on :: port 22.
s6-rc: info: service legacy-services successfully started
vielleicht kann einer helfen Danke Oliver
Hooo Hooo
Es lag am falschen Passwort geht !!!
Entschuldigt, bin leider grober Anfänger Gruß Oliver
